View Poll Results: Prefered ZF6 oil | |||
Amsoil |
8 | 25.81% |
Castrol |
16 | 51.61% |
GM 1052931 (stock oil) |
1 | 3.23% |
Mobil 1 |
3 | 9.68% |
Other |
0 | 0% |
Red Line |
3 | 9.68% |
Voters: 31. You may not vote on this poll |
![]() Join Date: Jan 2009
This is kind of a rehash but with a poll to document in an easily viewed format what everyone uses.
This is the long form of the poll with more detailed info from what others have posted. stock GM 1052931 Castrol RS 10W60 (or similar castrol) Amsoil synchromesh Mobil 10w30 Red Line MTL
Scott ![]() Vett owner since 1979._It's about the car and the people Last edited by scottfab; 01-28-2013 at 11:12 AM. |
![]() Join Date: Jan 2010
Thought I was gonna use Castrol TWS 10W-60 till I went looking for it locally...
Most places haven't even heard of it! The local foreign car parts place recommended Liqui Moly 10W-60 Synthoil Race Tech GT1 @ $20 a liter from Germany. He sells this to M3 owners. Anyone ever use it? Maybe I'll just get the Castrol TWS 10W-60 on-line and quit screwing around... It's probably available at the local BMW stealership but I try to avoid them if at all possible. |
I am about the task of swapping out all fluids when I came upon something I made 15yrs ago for getting the fill and drain plugs out
of the ZF6. It's a 11/16in nut welded to a 1-1/16in nut. It is low profile for getting in that tight space at the fill plug and can be place inside a 1-1/16th in socket for use with a ratchet. AND if you were careful not to over tighten the plugs the last time you change oil the whole process of removing the drain plug and fill plug is a breeze.
#4 | |
![]() Join Date: May 2011
I actually did not expect it to work so I just goobered it together.
When it showed to be strong I flung it into the toolbox drawer with the allen wrenches. I was lucky to find it again. Hell it still has slag on it.
#6 | |
![]() Yes on............4.4 pints - Castrol TWS 10/60 ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS |
#7 | |
It fits in tighter than 17mm which is a good thing. Nothing that comes in a green bottle can be any good. ![]()
#8 | |
![]() I assume you do not have to tap the 11/16 nut into the 17 mm Allen socket and assume there is no road rash on the bottom 17 mm transmission drain plug. On your opinion of the green oil bottle.....I am not so sure ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-29-2013 at 08:09 AM. |
#9 | |
#10 |
![]() Join Date: Jul 2005
I switched to Castrol from Red Line after my trans seized. Bill B. said he's seen several ZF's with Red Line do this. My experience and Bill's WOM was justification enough for me to change...
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int |
