My emblem is really faded ... I was curious if there is a good source for a replacement?
What is the procedure for this, is the old one held on by 2 mounts into holes on the body? Please share if you know of a place, thanks ![]() |
Ebay.
Madvet.com or Ecklers has these sometimes a good price can be found on ebay as well. Removal can be a chore its not just two nuts but adhesive underneath. I use thin gauge weed wacker line and GooGone to remove the adhesive remnents. Work the weed wacker line back and forth like a saw and it wont mar the paint. GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-23-2013 at 01:12 PM. |
What is it usually listed as " Gas Tank Corvette Emblem " ... are the 90's different than the other years?
So there are two bolts AND adhesive? Im guessing the bolts can be seen when the gas tank lid is up , lol ... I will look next time I fill up. I haven't noticed them before. Just use RTV to reapply the new emblem? What do you think about Corvette Central, reputable but pricey? --- Thanks ![]() |
![]() Join Date: Jan 2007
I ordered new ones in the past. The new one will come with an adhesive backing covered with a thin sheet of plastic. I only attached it with the nuts and left the plastic sheeting on. When it comes time to wax all I need to do is take off the nuts, pop it off, wax and put it back on. It's neat and clean.
![]() Join Date: May 2012
FYI
Be careful removing or tightening the lock-nuts on the emblem. The post is only plastic and can breakoff easily...been there, done that. ![]()
![]() Last edited by Paul in SC; 01-23-2013 at 10:57 AM. Reason: copy edit |
Thanks guys ... sounds pretty simple , I appreciate the tips though!!! ---
Is it the same procedure for the hood emblem? I see they sell them as "front and rear" sets ... I may as well get a new one on the front too
![]() Thanks guys --- |
#9 | |
Also the new emblems are not threaded they are plastic posts or pins. Do not try to chase the original nuts you remove from your old emblem onto the posts or they will snap off. Go to ACE Hardware with emblem in hand to get the right size chase nuts that cut a thread into the posts as they tighten. GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-23-2013 at 01:20 PM. |
#10 | |
