Old 01-16-2013   #1
vilant
Default New car scanner
So I just got the software for my new car scanner (turns your laptop into a scanner). It's got a ton of features, but I can't wait to test the built in dyno and accerlation tests it has.
I sense some cold air intake tests in the near future .
Old 01-16-2013   #2
Default Re: New car scanner
Joe how much was the software? Does it data log as well? Does it run in a Windows 7 environment? GC
Old 01-16-2013   #3
vilant
Hey GC, I was looking at this software a few months ago and it was $197 just for the software. Then I looked again a week or so ago and saw they were selling it for $97 so I jumped on it. You will also need to buy the OBD II USB cord ($35 (for my other cars)) and the OBD I USB for the ZR-1 ($60). I also bought an inverter from Autozone for $25 (but not necessary if you charge up your laptop first).
Old 01-16-2013   #4
vilant
Oh and yes it works on several platforms, Windows XP, Vista, 7 and 8. I haven't tried the data logging but it does have it. I really haven't had a chance to play with it yet. Only reset some lights on my pick-up.
Old 01-16-2013   #5
Fully Vetted
Fully Vetted's Avatar
Which scanner are you using for this software?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 01-16-2013   #6
vilant
It's software for your laptop, the program is called Scanmaster-ELM and is sold by Total Car Diagnostics. Not sure what you mean by which scanner, I use my laptop, just plug it into my car with the USB cords.
Old 01-16-2013   #7
Fully Vetted
Gotcha. I thought you used a stand alone scanner plugged into your laptop and then this is the software for it. If I'd read your first post correctly you explained it pretty well.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 01-16-2013   #8
do you have a link for more info.. Searching Total Car Diagnostics.. shows info but say for OBD 1 only Corvette (16 Pin) ALDL is supported I am quite sure my 1990 is 12 pin
Old 01-16-2013   #9
Fully Vetted
Here's a 16 pin or 12 pin:
http://www.aldlcable.com/
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 01-16-2013   #10
scottfab
scottfab's Avatar
On a related note, here is a forum of interest for scantools.
https://www.scantool.net/forum/index...itisirn9d4la7&
Scott
