Old 01-14-2013   #1
Schrade
Default Some stray shots of the auto...
I got only the front end in the air, and shot one-handed.
Hard to see much, except for some transmission fluid . More elevation tomorrow, with some close-ups...
If anything looks awry, sound off; I need to know how close to look here...
Old 01-14-2013   #2
Schrade
Default Re: Some stray shots of the auto...
Old 01-14-2013   #3
Schrade
Old 01-14-2013   #4
Schrade
Old 01-14-2013   #5
VetteVet
VetteVet's Avatar
There's your Transmission Controller wires coming out of the passenger floor near the fuel filter. Like I suspected from your other thread, there's no seal or sealant at all.
Did they not even install a torque converter cover on the trans? Or did you remove it for the pictures?
Jep
Old 01-14-2013   #6
aafc
aafc's Avatar
When i installed my auto(4l8OE) it left no room for transmission cover. The
Jeal headers came to close to the bell housing of the 4l8OE. Plus it
helps with the cooling of the converter. Have been running without trans cover
since Aug. 2004 no trouble. There is a putty that plumbers use that stays soft
but will seal up holes in your floor.
1990 white/black #2546 auto
aafc is offline   Reply With Quote
Old 01-14-2013   #7
Schrade
Jep
They put no cover on the TC. $1k for that lavender gem, AND PETE's flexplate, and no protection . Nice work.
At the local shop today, the tech gave me a plastic cover. It would not dry-fit into place - the cats blocked it.
I think that if the plastic cover is split in half, each half will mount securely, perhaps with a tie plate in addition, since it's not load-bearing.
And that hole in the floorboard should be oval. With a securing strap securing it - one inside, one outside. Nice work.
Old 01-15-2013   #8
scottfab
scottfab's Avatar
So the torque converter and flywheel are just spinning in the air ready to suck up plastic bags and such?
Scott
Old 01-15-2013   #9
I dont know for the price you paid I think they should have figured out a cover for you as to the wiring job wow no comment beyond what has already been said.
