Old 01-13-2013   #1
Schrade
Default Is this factory harness routing? [snappic]
It's forward in the passenger side foot area...
Old 01-13-2013   #2
sammy
Default Re: Is this factory harness routing? [snappic]
no it isn't. what is the fast unit for ? you have 2 extra fuses ?????tyler could tell you for sure .
Old 01-13-2013   #3
aafc
aafc's Avatar
No,
It looks like its your transmission controller and wiring.I hid mine in my glove
box. I used a transmission control unit by Compushift .
John Becker
1990 # 2546
aafc is offline   Reply With Quote
Old 01-13-2013   #4
Schrade
Nice grommet. They'll never fit a grommet in there, until they sharpen their hammer a little more.
The controller is for the automatic transmission that just went in.
And I'm believing that the shop that did the swap did this. I'll know for sure tomorrow, when I follow the harness.
And this is new too:
Old 01-13-2013   #5
Fully Vetted
Fully Vetted's Avatar
It looks like that yellow wire has been pinched almost to the point of being cut off. Look at the indentation in the wire right before it disappears.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 01-13-2013   #6
tpr60
Be carefull, yellow wires like that are part of the air bag system.
tpr60 is offline   Reply With Quote
Old 01-14-2013   #7
WVZR-1
A good observation.
If the "yellow" is a "sleeve/sheath" over existing other wires yes it is an SIR related harness. If it's a stranded wire just yellow in color it was more likely just a poor color choice. If it is SIR in a '90MY the DERM/SIR is top of tunnel and is "orange" in color, harnesses in and out are yellow sheathed. Just follow the yellow to where it's terminated.
Were you provided with the hand-held unit that accompanies the TCU controller? Here's a link to the install sheets for the TCU unit I believe you have. I was attempting to ID the loose connector on the floor board. Does it need attention? Don't know!
TCU/CONTROLLER INSTALL INSTRUCTIONS:
http://news.compperformance.com/Inst...s/CPG5-103.pdf
Old 01-14-2013   #8
Schrade
Yes Sir Bob, and I am VERY familiar with airbags. Today at the tranny shop, with the Tech 1 plugged in, it started fading in, and out INF RES (or something)...
I hit one @ 55 once - 55 - 0 in ZERO, ZERO exaggeration - it's all on the report, head on with drinker, also going 55+, SQUARE.
Still broke 6 ribs on the steering wheel, 3 bilateral in the pattern of the wheel (amongst other 'breakage') WAH
