Old 01-13-2013   #1
Schrade
Default Vacuum pump? Why does it buzz every 10 seconds? [snappic]
edit:
Mr. Dynomite said it's a normal function, SO, can some rubber bushings / washers be fab'bed to re-mount this pump, and create a 'buffer' effect and possibly reduce the noise???
__________________________________________________ _________________________
Where is the snooze button on this guy? He buzzes for about 1 - 2 seconds, every 12 - 15 seconds.
Is a fault or error indicated? Whatever it is, I can'T pin the rap on the shop that did the tranny - it did it before...
Only DTC I've seen was for voltage to LED cluster...
Old 01-13-2013   #2
Schrade
Default Re: Vacuum pump? Why does it buzz every 10 seconds? [snappic]
Thanks there Sir...
(didn't know what to look for in FSM )
Old 01-13-2013   #3
ghlkal
ghlkal's Avatar
edit:
As Cliff said, this is normal.
Can you actually hear the pump when driving? If so, increase the revs until you can't hear it anymore ...
Old 01-13-2013   #4
Schrade
No Sir - can't hear it while driving, but I can just hear it while idling.
So if I TIME the intervals, I can guage a vac. leak? Does the interval have a normal spec time? Such as for a new motor? Is it in FSM?
I don't have a loping idle, which is usually a tell-tale indication of intake leak...
And is the ground for the vac pump integrated into the mount? I'd really like to fab up some cushion into mounting bushings...
Old 01-13-2013   #5
Fully Vetted
Fully Vetted's Avatar
...increase the revs until you can't hear it anymore
That's otherwise known as the HGIH or High Gear Indicator Hum. It's an indicator that you are at least 2 gears too high.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 01-13-2013   #6
Blue Flame Restorations
Remove the secondary system and it'll be as quiet as a ZR-1!!! Seriously, remove them. Glad I did.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 01-13-2013   #7
ghlkal
ghlkal's Avatar
I don't know what "normal" should be. Mine starts up every 15 seconds or so like yours. Marc H told me that as long as the pump shuts off for a few seconds then it is "in specs."
Old 01-14-2013   #8
scottfab
scottfab's Avatar
This is not normal. 10sec is too short of an interval.
It's easy to get it to 30sec or more.
DON'T rip it all out !
Just fix it like you would a burned out light bulb.
You also should not trade the car in for a new one
when the ash tray is full.
Start with the basics.
Find the hard plastic hose that comes out of the pump and
pull it out. Then put you finger over the side coming from the pump.
It should run a bit then stop for an indefinite period of time.
Report back then we can direct you to the next step.
(or find the old thread that covers this to send you too)
Scott
Old 01-14-2013   #9
Or just remove it and never have to worry about it again
On a side note------I did the Ash Tray Relocation mod and put it in the center console for quarters for the car wash. No ash tray, no temptation to sell the car........
Old 01-14-2013   #10
WVZR-1
You also have a cruise that doesn't work so I wouldn't panic regarding this. From the appearance of some of the install, the fact that they did a "pedal swap" I'm quite sure you'll find solutions in your search. You might check and see if your CHMSL works. They may have not understood the function of the switch that does the vacuum for the cruise and the 12V to the CHMSL!
You might have a few more surprises.
Patience!
