Old 12-05-2012   #1
Schrade
Default Need Memory / Calibration module for '90; re: TSB 47-65-03
Anyone know where I might find this part? My '90 is low mileage, and the PO apparently was never made aware of the upgrade part...
If I can find an ECM in a vette salvage yard, is the ECM typically marked for this service upgrade???
Would any later model LT5 ECM be hot-swap capable?
Old 12-05-2012   #2
Schrade
Default Re: Need Memory / Calibration module for '90; re: TSB 47-65-03
Found the Haibeck / ZR1 Specialist site; hope still to get responses of my other Q's here...
Old 12-05-2012   #3
ECMs are not hot swappable.. But you can use any year LT5 ECM in your 90. The service upgrade is just the MEMCAL that is socketed in the ECM. I would suggest just getting a custom MEMCAL done by Marc for your car.
Old 12-06-2012   #4
scottfab
scottfab's Avatar
...snip...
Jeff is correct the ECMs are not "hot-swappable".
"hot-swap" usually means changing the unit with power on and/or car running. However, if what you meant was can the later ECMs be used in earlier cars, then yes.
Scott
Old 12-06-2012   #5
Schrade
Just did exactly that - ordered from M Haibeck.
Seemed like a real pleasant and knowledgeable guy there; obviously not his first day! He'll probably see more of my business...
Old 12-07-2012   #6
ghlkal
ghlkal's Avatar
He's a good guy, and there are plenty of helpful folks on this forum too.
