Old 12-04-2012   #1
boostedmaxPSI
Default Benifit of tuning after headers are installed
After months of waiting for some headers to be made I decided a different route and purchased some SW with high flow cats and thermal coating.
I plan on doing the install ( wish me luck or advice, I'll take both )
My question is: what is the value and typical gain from getting the car tuned after my headers are installed?
Thx
FS
boostedmaxPSI is offline   Reply With Quote
Old 12-04-2012   #2
Default Re: Benifit of tuning after headers are installed
Thx
FS
Frank
Congrats!!!!
Expect 20 to 25 rwhp with headers. (A little less with cats)
Old 12-04-2012   #3
Not knowing your AFR ratio at WOT before installing headers is rolling the dice a bit. I experienced a suprise lean condition at WOT when I first bought the car. So, I'd at least have Marc or someone burn you a chip calibrated for an additional 25 hp - just to be on the safe side.
As for realizing max potential, a dyno session is probably the only way you'll know if you're getting the most out of the system. I'd make a point of getting it tuned soon as possible after you install the headers.
P.
Old 12-04-2012   #4
boostedmaxPSI
Thanks for the replies.
Seems my question was a bit confusing.
I am Interested in understanding how critical it is to retune my car after the headers are installed. Most cars come from the factory on the rich side... I was curious if the headers leaned it out a bit and still be on the safe side or now it's too lean hence the need for a retune.
Is it possible to just send my chip off for a reburn to account for the headers or should I go thru another Dyno tune session?
Thanks
FS
Old 12-04-2012   #5
Not getting your tune right after a header install can invoke Knock Retard due to a lean condiiton depending on state of tune . So you won't see the full benefit of better exhaust since the ECM will be dialing back the timing a bit. Part throttle also needs tweaking to optimize for the change in backpressure.
Old 12-04-2012   #6
PhillipsLT5
PhillipsLT5's Avatar
Marc can burn you a "generic" header chip with any other mods, but a dyno session will put you closer to max potential
