Old 11-21-2012   #1
vilant
Default Changed my air box
I switched my air box from this aftermarket one
to this mostly original air box
I had the original plastic bottom, but was missing the screws and top piece. A big thank you to Dave J. for giving me his old air box (actually only ended up using the screws, Dave. Have everything else if you would like it back) . The top piece I did have turns out (after some looking for the original) to be an aftermarket for a 94'-95' ZR-1. They say it will fit a 90', but it turns out it doesn't quite make it. The shroud that is on top, keeps it from sliding all the way down so the screws can catch. Look at the one on the right.
So I drilled out the rivets holding it on, and wah-la, it now fits.
Problem is the paint is missing where the shroud use to be. I colored it in w/ black marker for now, lol. But eventually I'll take it to a friend, have it sanded and repainted. You can't tell unless you stick your head down in there and look.
Once I have the holes filled in where the rivets were and repainted, it should look just like an original 90' air box top. I'm sure I could just sand down the piece and paint it myself, but I can have it done cheap. Quick, easy way to turn the 94-95 part to a 90.
Old 11-21-2012   #2
Kevin
Kevin's Avatar
Default Re: Changed my air box
looks good. i have my stock one kicking around somewhere, i'm running an open one now
Old 11-21-2012   #3
Looks good.
Old 11-22-2012   #4
Looks nicely done!
I had one of those (SLP?) "Claw" intakes on my 95 LT1 car. Intuitively speaking, it looked to have some potential over stock, but never dyno'ed it to actually see if function = form.
The stock intake on the LT5s is an area worth exploring, far as improvements go. Case in point: The vacuum is so great that often the accorion tube will collapse at WOT, in spite of an open lid box (I discovered).
1) The collapsing screams "impedance" at the opening of the tube; enough so that there is a pressure drop within the snorkel sufficient for outside air pressure to collapse the unsupported tube. And, when applying principles of "laminar flow", it would be difficult to find a surface with greater impedance than that accordion style tube bridging between the filter and the intake horn. (This was addressed on the C5 and C6 with the smooth carbon fiber bridge instead.) Installing hoops keeps the tube from collapsing, but does nothing for (theoretical**) surface impedance/internal pressure drop.
2) The "Coplan" sleeve insert does provide a bridge over the accordion surface, which has to be an improvement to flow (I'd bet a ham sandwich on it!).
**Note: I have to leave it at "theoretical" based on observation and basic flow principles. But, w/o actual quanitative measurements of air pressure or velocity to prove it, quantification is stll "at large".
So, from a flow dynamics point of view, the "Claw" appeals to my sense of flow, compared to stock. Sure would be interesting to see some "before and after and back again" dyno comparison of that system and stock.
I'm just sayin. This is a topic I'm studyin' up on at present, in conjunction with increases in TB area, is why all the elaboration. (Don't mean to steel the thread)
P.
Old 11-22-2012   #5
One indicator of inlet performance would be how close to 100kPa you get at WOT.
Old 11-22-2012   #6
No agruement, but a simple vacuum gauge in the intake horn, as in a "before and after" test, would be easily done as cheap test...methinks. No?
P.
Old 11-22-2012   #7
vilant
Thanks, guys, I don't know if it looks good, lol, but it will when I have it painted.
Paul, the claw was still connected to the air horn via the accordian. Are you saying the accordian would collapse at WOT w/ the original air box but not the claw? Or either, because of the accordian? How did you find out it was collapsing? And where do you find the insert your talking about? It would be interesting to see what the difference is between the two on a dyno. I have both, but it costs $150 for 3 runs on a dyno at the shop near me. Not sure I want to spend that to quell my curiousity though, lol.
Old 11-22-2012   #8
Kevin
Kevin's Avatar
The accordion will collapse matter what set up you have. You can check by watching it while you open the plates by hand. You will see it sick down. The coplan duct is no longer available, I know because I bought the last one from him at bg a few years ago. It's a stock looking duct with a an aluminum insert in it. Back in the day we also used a coffee can...but I can't remember the last time I saw a metal coffee can.
Before buying the duct from mark, I went through several factory ducts and due to the under hood heat they get soft and suck closed under acceleration. I remember thinking Keith's black car had bad injectors when we saw his dyno numbers, mr. Haibeck saw that his duct was collapsing. Mr. Haibeck sells hoops to keep this from happening.
Old 11-22-2012   #9
I bought this one for mine. Tough to install but it's pretty stiff and smooth. Also reasonable at 44 bucks.
http://www.ebay.com/itm/ZR1-ZR-1-LT5...0372f8&vxp=mtr
The MAP sensor is effectively giving you a "before and after" since before is 1atm. Of course you need a scan tool to read it.
I learned this year that Marc removes his air filter also when he runs the car in addition to removing his mufflers.
Old 11-22-2012   #10
Yep thats identical to the coplan insert that's made out of metal. Don't forget the haibeck hoops also solve the collapse problem. Both are nifty little mods
