![]() Join Date: Mar 2007
Well a Callaway on the rack and 2 Zs in the garage and one in the drive with the clutch issues. With Petes reasonable pricing I turned the keys over to him on the 90 Z for some sorting....not enough time in the day for me.
Pete has a pretty sweet setup *Replacing the clutch; sorting the engagement issue *had a slow leak from the engine, turns out I had a small leak out rear crank plug.....my machinist said he never touched it....not sure what happened, it did not effect oil pressure etc.... Pete took the car for a spin today pre-surgery.....hopefully on the dyno soon
![]() Join Date: Sep 2012
Keep us posted. Have you dynoed it before?
I have not, so shoulld be interesting....
I will let Pete comment on the cars power....it has some different features *Porting not as big as Petes but it is siamesed 1"into the head *Cam not as big on the Primary as Pete......other #s same as Petes custom grinds *Siamesed intake...all the way down....(some say torque may be down, but......) So I will be curious where it lands.....
![]() Join Date: Dec 2003
Well for as big as Lee's plenum and IH's are ported (siemesed) i did not feel any low end loss drives and pulls away like a stocker i was very impressed, still not tuned.
On the test drive tires were up in smoke pulled hard hit 7+k very fast suprised me i thought ok 4.10 rear gears,when i racked/raised the car i check rear end to my suprise it has stock 3.45 gears Lee don't bother with 4.10's Lee post some pictures of your huge IH ports ![]() Pete
![]() ![]() This is before I cleaned the ports up...... ![]()
Lee,how's the Z?
Have you been driving it? Pete
Shift is smooth.....2nd gear will need a redo.....as you know I picked up a new set of synchros from Ebay for $200; so it will be back at you once the project is done, I assume that means we need to hold off on the Dyno
![]() Clutch engagement is perfect..... The slow drip seems to be ok......for others, I thought for sure it was me not doing something right with the rear main seal; turns out the prior owner removed the rear plug and although it was tight and did not affect oil pressure.....it was leaky. and a warning to those changing their pilot bearing, check it with a magnet, some steel fakes out there and they do not like coming out ![]() If you need clutch, engine work, etc...Pete is the go to guy, work is perfect and price is very very very very reasonable.. Especially when you have 3 project cars going at once
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 11-16-2012 at 08:57 AM. |
Lee,
Second gear synchro shouldn't affect going to dyno. When u going? We could do a combo session. |
#9 |
![]() Join Date: Jan 2012
#10 |
That freak-in crank plug cost me dearly a few years ago on the road in Montana. Same thing started leaking after a reputable mechanic replaced the bearing, clutch ext. As it turned out The Kent Moore Tool kit has a special tool just to seat that plug as we'll as a sealant is mentioned in Corvette Service . GM had a few other blocks for trucks with a similar set -up and they had the proper equipment, and familiar with the procedures working on the trucks that had the same type of plug.
No leak 3 years this month. watch it. When it goes, it goes. |
