Old 11-05-2012   #1
robbz28
Default Not so smooth Idle
My car runs pretty good and it idles down low where it should, but its ever so faint, you can hear a miss every now and again. It idles a tad bit erratic, not that its major, but enough to make me want to figure out what it is. It also has a slight hesitation from idle to when I give it some gas. If it's idled up it don't have this hesitation. It's almost like theres not enough gas available. I am going to start going through the ignition system bit by bit. First I will change the plugs, if it persists, test coil packs and wires. I got this car about 1000k miles ago and not sure when this stuff was changed last (if ever). It has 70k miles on the whole car, but the engine had about 35k on it when LPE did its thing to it, but that did not include altering the ignition system. Any tips, anything else I should check out?
robbz28 is offline   Reply With Quote
Old 11-05-2012   #2
Kevin
Kevin's Avatar
Default Re: Not so smooth Idle
a "slight miss" being felt is a major miss being absorbed by the DM flywheel if you still have it. injectors, plugs are a good place to start. pull the plugs and see how they look
Old 11-05-2012   #3
Details help
When work was done and what was done in the past
Likely the typical:
Fuel injectors
Coil packs
Spark plugs and wires
Check with daniel in Louisiana (he has done these changes a few times)
Old 11-05-2012   #4
robbz28
I can't say that I actually "feel" the miss. I just can hear it, I suppose I can feel it when I rev it up to about 2k and hold it.
And as for the work, 35k miles ago LPE tore it down and ported the heads, intake, bored it to a 368, put new rods ans 12:1 pistons in it. "Chipped" it to match the new setup. No cam change, no headers.
I have been trying to get it to run like it should since I got it, and it runs awesome right now, but this little miss needs attention.
Old 11-05-2012   #5
Did this start when LPE did their "thing"? What mods did LPE do?
Old 11-05-2012   #6
robbz28
Oh I listed the mods earlier in the post. This was done years ago. Its been like this sinfe ive had it.
Old 11-05-2012   #7
PhillipsLT5
PhillipsLT5's Avatar
Have you contacted LPE about mods
Try
http://www.linkedin.com/pub/dir/Graham/Behan
Old 11-05-2012   #8
You could also send me the memcal and I'd read it.
Old 11-05-2012   #9
scottfab
scottfab's Avatar
When was the last time injector cleaner was run though?
Cheap and easy to do compared to coils etc.
I run the Techron stuff through once a year on 1/4 tank
before bed time in winter.
Scott
Old 11-05-2012   #10
robbz28
The mem-what?
