![]() Join Date: Aug 2012
I have found mixed replies to this question on the internet but nothing as direct as I would like. I had a vaccum leak and it was causing my secondaries to only open some of the time. So I pulled my plenum, did some checking and managed to get the leak down to a manageable amount, but I went ahead and used a tie strap and tied the actuators open on both sides. (My car has the LPE 530 kit on it where it is in "full" mode at all times) I figured what would it hurt, what's the difference in this and removing the guts completely. Anyone else done this? Any adverse effects? Been running my car like this for about 500 miles and no issues yet.
One more question, anyone ever run any 100 octane low-lead aviation fuel? |
I believe Dominic has pinned back his butterflies. XfireZ51
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 11-05-2012 at 02:39 PM. |
![]() Join Date: Feb 2011
100LL used to be a cheap way to get some octane to run nitrous on an 11:1 street-strip carbed muscle car I had, but if you still have catalysts, look out, it will quickly break the substrate up into rattling chunks.
I'm not 100% certain on the cats, I think they are there, but one tank probably wouldn't hurt. My car has 12:1...but it runs good on 93, just wondering if there would be a noticable difference with the 100.
i knew the 02 sensors would have a problem but gas + flame fixes tat
Was your calibration modified to run 2 injectors all the time? By opening the secondaries permanently, air is moving through the secondary runner as well. I suspect there some loss of velocity thru the primary runner but primary injector is spraying fuel only into one air stream while secondary air is getting into chamber without any fuel. You're getting enough fuel but not an even mixture IMO.
#8 | |
Good man
#9 | |
#10 |
You should be able to buy 100 unlead race gas, it will be pricey, $6 to 8 per gallon
This should help http://www.osbornauto.com/blend.htm |
