Old 11-04-2012   #1
dredgeguy
dredgeguy's Avatar
Default Help, oil overfill
Oil level was way down and I picked up some Mobile 1 at Costco. they had a sale on Mobile 1 5W-30 and 10W-30 oil for $26.99 for a 6 pack. Put it in too much. The oil dipstick now registers oil higher than the hash marks, between the U and L on FULL.
Questions:
1) Is it OK to drive in this condition?
2) If oil has to be removed, can I siphon oil out by removing the oil filter and using a manual siphon pump?
Last resort if oil needs to come out would be to drive to a gas station and have them put on a lift and drain some oil out. I do not have a lift or ramp at home.
Looking for any suggestions and thanks.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 11-04-2012   #2
nelson007
nelson007's Avatar
Default Re: Help, oil overfill
Hello Charlie,
I don't if it will do any harm. I have a electric oil pump that will suck out the oil through the dip stick hole if you need to use it. I used it to change the oil in my boat.
Thanks
Nelson
nelson007 is offline   Reply With Quote
Old 11-04-2012   #3
SteelBlueZR1
Good morning Charlie,
If it is beyond just above full, would take it to the shop who changed the oil and have it drained ASAP just in case... Too much oil = too much pressure. Manual says "do not overfill."
After all the oil leak potentials the LT5 has, I would not mess around: see : http://www.zr1specialist.com/HAT%20W...0the%20LT5.pdf
Plus, next time you change the oil, switch to - Mobil 1 High Mileage as it is the best phosphorous/zinc formulation by Mobil1 for the LT5, per Marc Haibeck: see http://www.zr1specialist.com/HAT%20W...5%20Engine.pdf
One last over complication, but great read for 2 new z owners on oil filters Haibeck says now use only OEM Blue PF970C AC Delco as most others' anti drain back valves leak = chain rattle at start up: see :
http://www.zr1specialist.com/HAT%20W...r%20Review.pdf
Hope to see you and Nelson soon... Can't wait to see Nelson's New Ruby Z!
Bert
Old 11-04-2012   #4
dredgeguy
dredgeguy's Avatar
Thanks guys. Think the best solution is to drive to the closest station and have them drain some out. Will take oil with me in case they take too much out.
Not what I planned for my Sunday morning.............
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 11-04-2012   #5
It depends on how high the oil level is, i.e. how much it is overfilled. There have been a few reports of severe engine damage resulting from oil changes being made by shops & dealerships with no experience on the ZR-1 LT5 engine. Simply draining hot and refillinjg to the stated "capacity" would be nearly 3 qts over-fill. Even draining hot & refilling to the "change" volume would result in about 1 qt overfill.
Correctly checking oil level is a common issue with the LT5.
The best method is to check the oil level, before starting, after sitting overnight. The LT5 retains a lot of oil on the topside and drains down slowly. A correctly filled LT5 will show low when checked "hot".
Not knowing how much the overfill actually is, the safe thing to do would be to let it sit overnight, check the oil level & drain or suck out until the level is correct, WITHOUT STARTING the engine. Don't expect to add a qt of oil & see it show up on the dipstick in a couple of minutes. You cannot remove oil from the oil fill cap. As stated by an earlier post, you can remove with a dipstick oil vacuum.
If you must drive the car somewhere to drain oil, keep the rpm as low as possible. Remember, if you do this, the engine will be hot. Leave the oil level at the 1qt low mark, drive it home & let it sit overnight. Add 1/2 the amount shown "low" on the dipstick. Check again the next day. until it reads full when dead cold.
Old 11-04-2012   #6
dredgeguy
dredgeguy's Avatar
Thanks Jerry,
Just drove around with my other car and found that Mr. Tire is open and can drain some out. Will have them do that then get the Z home and sit until tomorrow, check it cold and adjust from there.
Thanks for the assistance.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 11-04-2012   #7
xlr8nflorida
xlr8nflorida's Avatar
I guess it depends on how much your LT-5 is overfilled.
Personally, I would not drive it. 1 quart is probably not the end of the world but 3 is another story.
Why not just buy this unit for $85.00 and get the oil out yourself without starting the engine.
http://www.amazon.com/s/?ie=UTF8&key...l_6o9gsdta00_e
Here is the mityvac website with several options for extractors. Mityvac is not going be the cheapest but they are quality.
http://mityvac.com/pages/products_fee.asp
Another option is to simply borrow Nelson's pump.
I've had my Mityvac for a year or two and it works fantastic on the LT-5. Well worth the $95 I paid for it. It does all type of fluid changes.
Old 11-04-2012   #8
dredgeguy
dredgeguy's Avatar
Thanks to all. Drove the car at around 1500 rpm the 3 miles to Mr. Tire. Oil temp was less than 105 when I got there.
They drained 4 quarts and then put 2 back in. It is reading low but will let it sit overnight and check in the morning and add from there.
What a learning experience and thanks to all for the suggestions and offers of assistance.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 11-04-2012   #9
Kevin
Kevin's Avatar
you could have just cracked the drain plug and drained some out
Old 11-04-2012   #10
scottfab
scottfab's Avatar
...snip
If your oil level is higher than normal in the oil pan but not comingling with the crankshaft during engine operation, maybe you have some oil pan leaks (if you have loose oil pan bolts...and most do if those bolts are not checked) but seems to me that is no harm and no foul.
What is a "comingling" ?
As for the overfill.....
Don't sweat it. Crank and start the engine for a few seconds then shut it off and take the filter off and put it in an oil drain pan to let it drain out. After 8hrs or so check the oil level. If it is high reinstall the filter and start it up again.
Repeat until level is nominal. This works. I've done it.
Scott
