Old 10-24-2012   #1
Kevin
Kevin's Avatar
Default c7 engine specs out
New Chevrolet Corvette V8 is 6.2 liters, designated LT1. Not the first time a Corvette engine has that RPO code.
0 to 60 mph in less than 4 seconds. Entry-level car. 450 hp or more!
New Corvette WILL use cylinder deactivation. Go from 6.2 V8 to 3.1 V4 for better fuel economy.
New V8 engine has 11.5:1 compression ratio. Direct fuel injection, cylinder deactivation; continuously variable valve timing; active fuel management
450 hp 450 lb-ft of torque. More than 26 mpg!
New engine has a unique and complex piston head.
New LT1 V8 has 50 lb-ft more low-end torque than current LS3 V8; matches the LS7 V8 from the Z06.
LT1 engine to be built at Tonawanda engine plant in Buffalo.
Premium fuel recommended, but not required.
Spark plug is in the center of the chamber. Intake and exhaust valves are reversed.
There will be an optional 11.5 quart dry sump oil system available for the new LT1 V8
6,600 RPM fuel cut off in the new LT1 motor
All the new technologies on the LT1 make it a heavier motor than the LS3
Patent-pending PCV system
Final performance ratings will come in 2013
LT1 Engine build animation video --> http://www.youtube.com/watch?v=9E-DQ1qQyJk
Peak horsepower around 6,000 RPM; peak torque around 4,000 RPM
New combustion process to be documented in an SAE paper to be published in the Spring of 2013
LT1 is the first OHV engine with Direct Injection
i'm actively not interested in owning one now
Old 10-24-2012   #2
Default Re: c7 engine specs out
Can the LT-5 designation be far behind?
Old 10-24-2012   #3
Kevin
Kevin's Avatar
god i hope so
Old 10-24-2012   #4
MikeGolf
More info and pictures
http://corvetteactioncenter.com/spec...owertrain.html
MikeGolf is offline   Reply With Quote
Old 10-24-2012   #5
"it's a Hemi"
Check out the size of the ports on that engine !!
Old 10-24-2012   #6
Kevin
Kevin's Avatar
i now have some ford sackridding jagoff trolling me on facebook saying the gt5000lbs is better
Old 10-24-2012   #7
Corbusa
the gt5000 is better !! Off a cliff !
Old 10-24-2012   #8
And a big cliff at that.
See what the increased compression did to the torque on the "new" LT1 ? Not bad !
Old 10-24-2012   #9
Hog
I'm surprised at the discplacement staying up at 6.2 liters for the new GEN V small block Chev engine.
There seems to be a lot of new technology being used in the new C7 Vette engine wise, but quite a bit of it has been used prior in other platforms.
eg.DOD(Displacement On Demand) later renamed AFM(Active Fuel Management used in many GEN 4 engine such as 6.2 L99 and 5.3 truck engines.
VVT-Variable valve timing was used in earlier engines such as the 6.0 LY6 and some 6.2 GEN IV engines.
Good thing about doing so is that the GEN V LT1 might be a well integrated and polished engine.
Buy your 7.0l(427cid) engines while you can.
peace
Hog
Old 10-24-2012   #10
Corb,
I'm sure you meant the GT5*10squared correct?
