View Poll Results: How many miles per quart of oil do you get?
Over 7000 miles 6 15.79%
5000 to 7000 miles 2 5.26%
3000 to 5000 miles 4 10.53%
2000 to 3000 miles 6 15.79%
1000 to 2000 miles 13 34.21%
Under 2000 miles 7 18.42%
Voters: 38. You may not vote on this poll
Old 10-23-2012   #1
Default How many miles per quart of oil?
Thought it would be interesting to see what others are experiencing, far as oil consumption goes. I've heard and read where the LT5 is prone to using more oil than say SBCs, but if so, how much?
Please take the poll, and if you would, post up what has been done to your motor and how much spirited driving you will admit too!
Should be interesting.
NOTE: TYPO! THE BOTTOM CHOICE WAS SUPPOSE TO BE UNDER 1000. Please treat as under 1000 miles. (unable to edit the poll...a long time gripe with this software...)
P.
Old 10-23-2012   #2
efnfast
Default Re: How many miles per quart of oil?
Currently I've done headers and exhaust. Lost the cats. Installed a M.H. chip.
When I answered the poll, I'm just about 2000 miles, so I answered 2-3000.
Spirited driving? Oh-yeah. Usually sees a buck or better every time she comes out. I love the skinny pedal.
Paul, because you know how, how about a survey on miles per oil change? -Steve
Old 10-23-2012   #3
efnfast
Oh, BTW, I'm driving a MY90, so no exhaust valve seals. I ASSUME this contributes to oil consumption.
Old 10-23-2012   #4
SteelBlueZR1
8,500 mile 1991 ZR-1 has not used any motor oil in the past 5,000 miles, since oil change. Motor Stock, 10-30 Mobil 1 High Miles. Hard driving seldom, except for 2 recent autocrosses. Nowhere around Baltimore to safely explore ZR1 limits without going to jail.
Old 10-23-2012   #5
scottfab
scottfab's Avatar
Really depends on how I drive it of course. At the track I'll use a quart in 20 miles
Scott
Old 10-24-2012   #6
Okay, I voted "under 1000". I can make one quart vanish in an afternoon on a new O & F change.....all I need to do is stay above 3k rpms and never get to 5th gear; certainly never, ever get to 6th gear.
Bone Stock 90 LT5 with Marc's mail order EPROM.
Oil: M1 10w-30 full synthetic in the silver bottle w/silver cap.
Filter: it don't seem to matter whose I use, oil consumption is the same.
Okay, now for normal driving....I leave NYC, drive to BG and back and she will need a quart of oil. Usually that round trip is about 2200 miles. That's also on a fresh oil & filter change. Only thing is, I am fairly sure after driving with Jingles on a check ride I need to add some oil. JMHO on a 90 LT5 oil consumption maybe more a function of coolant temp and rpm. JMHO
Old 10-24-2012   #7
scottfab
scottfab's Avatar
Originally Posted by tomtom72 View Post
... snip...
Try adding one or two qts of 10w40 to lower consuption.
Works on my mostly stock 90. Remember we don't need no stinking exhaust valve seals. We have a true British influenced design.
Leaks/burns oil.
Scott
Old 10-24-2012   #8
scottfab
scottfab's Avatar
....snip...
P.
One of the more frustrating things about posting a poll.
DON'T make a mistake. No edit feature.
Been there done that.
Scott
Old 10-24-2012   #9
Leaks/burns oil.
Thanks Scott for the tip! I like your thought on the British influence! LOL Bravo! The way my motor behaves I almost think it likes the oil level to be at the "add" mark. The burn/use rate is waaay slower when it gets down to that point. However, I hardly ever get to 6th, and 5th rarely in normal driving unless it's early or very later and the roads are empty. JMHO, the higher the rpms, the higher the coolant temp, the higher the oil temp; the faster that hash area qt burns/is used up! I don't mind checking the oil before start up.
Old 10-24-2012   #10
mike100
Even though my last oil change was more than 2000 mi per qt, I put 1000-2000 because of previous history of adding qts when I drive it hard, which is the preferred method with my vette it would seem.
