![]() Join Date: Aug 2012
I have a problem and I wanted to just throw this out there before I break my multi-meter out and start poking around on the car. I have something, somewhere sucking the life out of my battery over the course of a week. I thought maybe I had a bad battery, took it to Autozone today and they tested it and said all's well. So are there any "usual suspects" as far as these cars go with this issue? I know my dome lights, under-hood lights, courtesey lights, and glove box lights are in working order. The radio is stock, but there is an aftermarket amplifer wired in to replace the bose speakers, but the power light on it is off when the car is. Maybe a stuck relay or something?? Where to start? What to do? My little 1.5 amp battery charger stays on it in the meantime.
![]() Join Date: Jul 2007
my best suggestion is to connect the multi-meter and pull one fuse at time and watch the current level..
but before that.. what was the last thing done to the car prior to this occurring?
Check the map lights in the visor as well. Is this a combo top and side post battery you have? G C
![]() Join Date: Aug 2006
Check and make sure door switch for courtesy light is working - shutting off after 15-20 seconds. These switches has been known to go bad.
![]() Join Date: Jan 2009
and the light that goes on when you open the center console.
If it is out of adjustment .... kills battery. if it stays on when the lid is shut. This one I know ![]()
That light don't work, not sure whats up with that, I tried to change the bulb and that didnt help, I hooked a test light up to it and got nothing...such an insignificant thing I'll worry about it later, but it might be a related incident (or just a bad connection). Anyway, I got my notepad out and hopefully this weekend can recruit my brother (a fellow zr1 owner) to help me pinpoint my issue.
Its been like this since i got the car...it sits for longer than a week and it needs a charge. I have had the car for about 6 weeks. It is a side post battery and the lights do turn off. The visor lights are off as well.
#8 | |
Based upon this response. Time to move onto -=Jeffs=- suggestion. Your brother can help you out during the fuse pulling multimeter process. GC
#9 |
Next I would suggest disconnecting the Stereo aftermarket amp and see if that fixes it..
Is there an aftermarket keyless entry or alarm on it?
#10 | |
![]() Join Date: Jan 2012
On my Z, the PO put in an aftermarket alarm system. What a PITA. It will suck the battery down after a week. It's on my list of things to pull out this winter. |
