Old 10-06-2012   #1
Blue Flame Restorations
Default Blowing INJ-1 Fuse
Trying to troubleshoot the 88. INJ-1 Fuse is 7.5 amps. Upon acceleration of RPM's the fuse will blow. SES light on.
Getting ready to count flashes.
Any input would be appreciated.
Thanks
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 10-06-2012   #2
Default Re: Blowing INJ-1 Fuse
Thanks
Brett, you didn't have the plenum off for any reason lately, didja? I pinched a wire once and had the same problem (fuse).
Might wanna "ohm" out the injector harness...methinks.
P.
Old 10-06-2012   #3
P.
Had it off many times last week.
Thanks, Paul. I'll check it out.
Old 10-06-2012   #4
Tyler and I figured it out. Problem solved. The INJ-1 circuit had too much draw.
Old 10-07-2012   #5
Why?
Old 10-07-2012   #6
Why?
We had piggy-backed that circuit while getting a constant 12 volts to the fuel pump.
Without getting too deep into it, I'm using the original harneses in the car. Every harness has damage that is being repaired.
The good news is, the car starts, holds good oil pressure and the charging system is functioning well. All gages work as well.
Old 10-08-2012   #7
It was something really simple.
During the work to get the car running, one of the original PhaseII injectors stuck open, dumping fuel into the oil. Had to change another $90 worth of oil and filter.
We installed new stainless injectors from FIC.
Long story short.........I checked the Turq car and the INJ fuse is a 10amp. The 88 fuse block called for a 7.5amp. I put a bigger fuse in and no more blown INJ fuses.
Old 10-09-2012   #8
Yeah, buddy! Out heyah in da sticks, ah sometimes put a penny in dar ta keep dem pesky foozes fum blowin alla time! (Juuust kiddin, Brett!)
Old 10-09-2012   #9
Aluminum foil works just as well. hahahahaha
