Old 09-27-2012   #1
carter200
carter200's Avatar
Default Coil over front and rear brackets........
Just a heads up that I will be finishing the front brackets tomorrow and will finish the rears by next Friday. You 7 know who you are and thanks for hanging in there.....
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 09-27-2012   #2
Default Re: Coil over front and rear brackets........
I did my fronts before your brackets, but the rears rock
Old 09-27-2012   #3
Ronstar
Are any other modifications necessary for coil over install
when using your brackets?
Ronstar is offline   Reply With Quote
Old 09-27-2012   #4
carter200
carter200's Avatar
Ron,
Not really a mod but you'll have to drill a .900 hole in the frame where my brackets relocate the coil over to the correct angle and depth. The brackets also are 10 times stronger than the original perch.
Ask anyone who has used them and they'll sing high praises for the brackets. Alot of science went into designing them. Thanks, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 09-28-2012   #5
Ronstar
so just install brackets and then its pretty much plug and play?
works with anybodys coilovers?
Old 09-28-2012   #6
pretty much with except of the added hole Carter talked about
yes assuming you are referring to C4 specific Coilovers..
I did my own and had Carter Machine some adapters for me..
so far no issues with mine
Old 09-28-2012   #7
carter200
carter200's Avatar
I remember machining those for you. That kit should last for ever!! Glad you are still happy after all these years......
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 10-05-2012   #8
carter200
carter200's Avatar
Default Re: Coil over front and rear brackets........ ***latest update***
I had planned on finishing the rear brackets today but had an emergency pop up and cost me a day and a half. I promise that I will be mailing out the front and rear brackets no later than Friday the 12th.
Thanks for your understanding.................
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 10-23-2012   #9
carter200
carter200's Avatar
Default Re: Coil over front and rear brackets........ ***UPDATE***
All brackets are done and mailed out today except for one person that ordered additional items and will send those items in the box along with the brackets.
It's taken longer than normal and expect faster delivery next time. Thanks all and enjoy.
Ted F., I shipped your brackets and will be doing your other items soon.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
