Old 09-22-2012   #1
Geof180
Default Alternator Replacement - with pictures
Good evening everyone,
I have done a search, and really didn't find a pictorial "how to" showing how to get the alternator out without pulling the plenum. So I figured I'd post up my procedure.
Well, I tackled this job tonight... And naturally with these old cars, nothing is ever as simple as it should be. Forgive me if some of the pictures are rather poor; I was using the trusty iPhone.
I will share my lessons learned. Hey, I have never done this before - and doing it yourself is always an experience. If I can help someone else avoid my own pitfalls, then I have succeeded.
1) Disconnect the battery
2) Remove the accordion air duct by loosening the hose clamps and removing the bolts securing the air cleaner assembly
3) Remove the air cleaner assembly
4) Disconnect the myriad of hoses and connectors running into the air horn
5) Remove the external and internal Torx bolts holding on the air horn
6) Remove the nuts holding the cover over the throttle body cables
The air horn is now free.
Geof180 is offline   Reply With Quote
Old 09-22-2012   #2
Geof180
Default Part 2
Be very careful of the gasket between this and the throttle body. Mine is now in two pieces.
My new one from Jerry's Gaskets should be here in a few days. It's a 20 dollar part.
7) I started removing the visible bolts holding on the alternator. The first one I did was the one nearest the oil pressure sensor.
Be very careful working around this sensor. My new one should be here in a few days. It's a 40 dollar part from CorvetteCentral
I needed more room to gain access to the lower bolts securing the alternator, as well as the belt tensioner.
8) I decided to remove the passenger side coolant crossover pipe so I could have more space.
There is a gasket here too. Again, Jerry's Gaskets says my new one will be here in a few days. It's like an 8 dollar part.
Oh yeah, despite the high location of the pipe, coolant is in there! It will come draining out! So drain some coolant beforehand if you plan on doing what I did.
9) I used my breaker bar and inserted the tab into the tensioner and pulled towards the passenger side to relieve the belt tension.
10) Remove the Torx bolts holding on the throttle body.
Old 09-22-2012   #3
Geof180
Default Part 3
There is a gasket here too! Surprisingly, mine stayed intact! . Jerry's does carry the part however.
11) There's a lower bracket with three bolts slightly below the alternator. I removed these bolts and thus the bracket.
12) After disconnecting the plug on theassenger side of the alternator, and the rear red wire, the alternator will simply slide out.
Now, be careful with the red wire on the back of the alternator. Mine more or less disintegrated when I tried to move it around. I will be splicing in a new wire tomorrow.
I hope this can help someone. After I get my new wire made, I am just gonna reverse the process to button the gal back up again. Oh yeah, replace the coolant which drained out too.
Old 09-22-2012   #4
Pete
Pete's Avatar
Default Re: Alternator Replacement - with pictures
Good job.
I like the powder coating (plenum/IH's) very nice.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 09-23-2012   #5
Thank you for the write up! Yea, nice work and the powder coat does look really great!
Old 09-23-2012   #6
scottfab
scottfab's Avatar
Wow would not have thought to do it that way.
Great write-up and pics.
I did the alternator replacement with just a few tools
in a hotel parking lot in 2005. Took 1.5hrs.
http://www.zr1netregistry.com/Old_Proj/old_proj23.htm
Scott
Old 09-23-2012   #7
Geof180
hey scott! i actually saw your procedure.
i thought about following your work, but i have never pulled the plenum.. so to be honest, i was rather nervous about doing so..
this is why i tried to do it without removing the intake..
and to tom and pete, thanks for compliments on the LT5's finish. i certainly cannot take credit for that.. this is all jeff flint's work.
Old 09-23-2012   #8
Mystic ZR-1
Mystic ZR-1's Avatar
Can ya get the AC compressor out using the same method?
Old 09-23-2012   #9
scottfab
scottfab's Avatar
Well it's good to know the other way works too. The only reason I felt confident about pulling the plenum was that I use a rubber gasket set under the plenum so I knew it would not stick and come apart on me.
That, I did not need being away from home and all.
Scott
Old 09-23-2012   #10
scottfab
scottfab's Avatar
Good question.
Scott
