View Poll Results: Does your state require emissions testing on rollers?
Yes 26 48.15%
No 27 50.00%
Don't know 1 1.85%
Voters: 54. You may not vote on this poll
Old 09-13-2012   #1
scottfab
scottfab's Avatar
Default Emissions Testing
Each state has their own way of measuring emissions.
In the state of Oregon one of the nice rules was that when
your car reached 20yrs old they no longer measured emissions.
That was very nice for my 73 LS6 because I had to put all the
air injection crap on it every 2yrs.
Anyway, I've just taken the ZR-1 down for testing here in
Washington and they no longer put the car up on rollers
for the test and they no longer inspect the gas cap !!!
Just a run up to 2500rpm for about 5seconds and that's it.
The PASS slip no longer shows levels of gases either.
Not sure if the FAIL slip does.
In a time when I see and hear that other states are stiffening up on
emissions it's good to live in a state that seems to be lightening up.
I am curious about how many states still use the rollers when doing emissions testing.
Scott
Old 09-13-2012   #2
Default Re: Emissions Testing
Hi Scott, yes I experienced the same change in testing procedures that NYS/DMV applied to cars in high density areas. It seems that two years ago the roller test was abandoned in favor of a short, fixed rpm test with an exhaust gas analyzer and a data link using the ALDL. Even the results of the analyzer are left off in favor of a "pass/fail" statement. The roller was not a state wide procedure, it was only in high density areas that actual tail pipe emissions through out a "simulated driving loop" were measured. There was a bit of 'raising the bar' with the emissions levels that they would call "passing" on older OBDI cars. It wasn't as bad a creep as CA is using, but I was beginning to think where will they stop. NYS/DMV Antique status is 25 yrs, and they have not decided to include OBDI cars in the same group as pre-OBDI cars that have an exemption from emissions testing in high density areas. I was always proud of my OBDI LT5 passing the testing even if it was shooting at a moving target.
I miss the actual gas content results. I used to use them as a "window" of sorts to what was going on inside the combustion chambers.
Old 09-13-2012   #3
Z Factor
Z Factor's Avatar
Smile Re: Emissions Testing
No testing whatsoever here in Florida.
Old 09-13-2012   #4
dredgeguy
dredgeguy's Avatar
In Maryland you can put Historic plates on your car when it is 20 years old. No emissions or state safety inspection is required with Historic plates.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 09-13-2012   #5
Locobob
Scott, last time I checked the Oregon 20yr old rule only applied to cars up to 1975 - so basically anything built after 1975 still had to pass emissions. Has this changed? Would be great if it has.
Robert
Old 09-13-2012   #6
scottfab
scottfab's Avatar
Ya know, I actually don't know where they are with that now. I lost interest in that along with the Ducks and Beavers in favor or the Huskies and the Cougars a decade ago
I do know my 73 did not have to go in anymore.
PS I decided to go with "Neighborhood Watch" for my new router name.
That should get some attention.
Scott
Old 09-13-2012   #7
Paul in SC
Paul in SC's Avatar
Ditto for South Carolina...
1993 ZR-1 - "The Green Thing", LPE/LSV 385; 2021 HTC, Red Mist Metallic, Cool gray interior, stainless dual stripes; ZR-1 Net Registry #1376
Paul in SC is offline   Reply With Quote
Old 09-13-2012   #8
efnfast
In NH as long as the "check engine" light isn't on, you pass. They figure the car is doing it's own testing continually. Makes sence to me.
Old 09-13-2012   #9
SteelBlueZR1
I never got to find out, as my 1991 ZR-1 is registered in MD as an Historic vehicle, and is thus exempt from safety and emissions inspections.
Old 09-13-2012   #10
Ronstar
No testing at all in Michigan
Ronstar is offline   Reply With Quote
