Old 08-26-2012   #1
Default Check out my TPI intake for the Callaway
Was going to build a 100+ intake for the Callaway; which is a Edelbrock tunnel ram cut down and a TPI plenum welded to it....they I saw this...it is the same height as a TPI and was apparently either a prototype for GM made by Jim McFarland or something made by SLP.... it has the GM winter foundry mark on it.....looks alot like the 100+ and it comes with new injectors and hi-po flow fuel rail(new)
paid $560 for it......I guess they made 5 of these....last one sold for $1K
Old 11-24-2012   #2
Default Re: Check out my TPI intake for the Callaway
Getting closer to finishing the Callaway
Old 11-24-2012   #3
Pretty cool Lee. Who's gonna tune it?
Old 11-25-2012   #4
Not sure about the tune, at this point just trying to get thing together, using a one off intake is a PITA, everything has to be custom made
Old 11-25-2012   #5
boostedmaxPSI
Looks good. Should really help add more rpm. I'm curious to see how your overall package works. Good luck, almost done.
boostedmaxPSI is offline   Reply With Quote
Old 11-26-2012   #6
Going to switch to 32lb injectors and not use the mircofuel system.
Old 11-26-2012   #7
Change injectors you'll need to change the calibration.
Old 11-26-2012   #8
boostedmaxPSI
Interesting. The stock injectors are plenty. Is there something wrong with the microfueler? I ditched my microfueler for a more modern setup. This allows me to run 16psi and more if I want. Tuning is a piece of cake now.
Old 11-26-2012   #9
I just do not want to risk the chance of the micro inj being bad, so FIC ran some #s and advised that 32s would make up for the microfueler.....
Old 12-06-2012   #10
USAFPILOT
USAFPILOT's Avatar
Is that a turbo car?
