Old 08-26-2012   #1
scottfab
scottfab's Avatar
Default Vacuum Pump Repair
I can't resist a challenge on repairing things.
Back about 12yrs ago my secondary vacuum pump failed.
I took it apart and replaced the diaphragm in it.
The I used epoxy to hold the cover for the diaphragm in place
and avoid leaks.
Well 12yrs later it fails again. This time I fashioned a bracket that
fits over the vacuum pump and holds the diaphragm in place.
This way I can get back in and put a new diaphragm in without having to chip away at the glue holding the cover for the diaphragm in.
Picture of damaged diaphragm
http://zr1.net/forum/album.php?album...pictureid=1445
Picture of bracket around pump
http://zr1.net/forum/album.php?album...pictureid=1446
Not the prettiest thing in the world but oh so functional.
Scott
Old 08-26-2012   #2
scottfab
scottfab's Avatar
Default Re: Vacuum Pump Repair
In the picture of the diaphragm you can see the split in the rubber right at the point where the metal washer touches it when it's in the pump.
Scott
Old 08-31-2012   #3
Corbusa
Sweet thanks for the info..
Old 09-01-2012   #4
4-cam
Mines in a box in the garage along with the rest of the secondary junk. I wont break if it isn't installed.
4-cam is offline   Reply With Quote
Old 09-01-2012   #5
scottfab
scottfab's Avatar
I'm happy for you. Thanks for sharing your insight.
Scott
Old 09-06-2012   #6
Don in VT
Hi Scott,
Nice pix, BTW, is that a TEK scope in the background ?
Cheers,
Don ( ex Tektronix engineer)
Don in VT is offline   Reply With Quote
Old 09-06-2012   #7
scottfab
scottfab's Avatar
Don
Yes as a matter of fact it is a 2230.
One of those I was responsible for.
(also ex Tektronix eng)
Scott
