Old 08-19-2012   #1
Rex Ruby
Default New Headliner
Earlier this year I replaced my headliner.
I tried to have a raised ZR1 in it and although a neat idea I failed and it looked like crap!
SO I bought some new headliner material and had some custom embroidery done
I think this time it is a success :thumbs:
Rex Ruby is offline   Reply With Quote
Old 08-19-2012   #2
Default Re: New Headliner
That's unreal!
I know who did it and know he won't make another!!!
Old 08-19-2012   #3
Rex Ruby
BET he could be talked into it with some $$$$.
Old 08-19-2012   #4
I just did my headliner too. Nothing fancy like yours, but what a difference! Definitely a DIY project. I followed the "101 Projects for your Corvette" book -- got a sheet of cork from Home Depot, material from Walmart, cut the pattern, glued in, and presto...headliner all fixed up.
Old 08-19-2012   #5
Kevin
Kevin's Avatar
would you happen to have a copy of the how to?
Old 08-19-2012   #6
cvette98pacecar
Originally Posted by ZZZZZR1 View Post
That's unreal!
Ask him if he would like to do two car covers.
Old 08-19-2012   #7
cvette98pacecar
Very Nice. another Winter project for the Purple Beasty.
Old 08-20-2012   #8
Rex Ruby
I removed the old material headliner and reused the factory fiberglass pad.
You may have to gently scrape or sand some of the old foam padding off.
Buy 2 cans of good spray adhesive and some new material.
Mask up the frame.
Lay out the new material and fold half back.
Apply the adhesive to the pad and the back of the new material.
Fold it over and fold the other side, apply adhesive and fold that down.
As you fold over with adhesive applied becareful to work the material down flat.
Trim the excess material about 3/8" longer than the edge.
That 3/8" will allow you to push the material under the frame.
2 hour job at most. Fairly easy. Nice upgrade to the interior.
Old 08-20-2012   #9
Now that looks very sharp! Nice work John!
Old 08-20-2012   #10
Scrrem
Scrrem's Avatar
Very nice John. May be a winter project for me.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
