Old 08-15-2012   #1
QB93Z
QB93Z's Avatar
Default Clearing the Oil Change Light
I am on a road trip and I don't have the owners manual with me. My Change Oil warning light is on.
Please post the procedure to clear the Change Oil Light.
Thanks
Old 08-15-2012   #2
Default Re: Clearing the Oil Change Light
Key on, Engine off.
Press ENG MET within 5 second press it again.
Press and hold GAUGES button. CHANGE OIL light will flash.
Hold until CHANGE OIL light stops flashing. When it stops it is reset
Old 08-15-2012   #3
scottfab
scottfab's Avatar
FYI for next time......
The reset info is in your Owner's Manual on page 86.
I keep a book mark there.
Depending on what MY you have this page could vary a bit.
Mine is a 90.
Scott
Old 08-15-2012   #4
Correct however hes driving the Yellow 94 for his road trip so the procedure is right. However there is no "Gauges" button to press for the MY90 or 91 as Scott is correctly pointing out.
Old 08-15-2012   #5
secondchance
Key on, Engine off.
Or place a small flathead screw driver in front of the "Change Oil" light. While holding the screwdriver w/ your left hand, grab a standard general purpose hammer w/ your right hand. Gently tap the end of the screw driver until the blade penetrates the plastic lense and break the lamp behind the plastic lense. Replace all tools back in the appropriate storage compartment - Just funning with you Jim.
Old 08-15-2012   #6
scottfab
scottfab's Avatar
Or carry some black electrical tape. Works !
Scott
Old 08-15-2012   #7
OH the horror
Old 08-15-2012   #8
QB93Z
QB93Z's Avatar
Thanks to all responders, especially the ones who posted a useful procedure.
Just Funnin'
Old 08-15-2012   #9
Kevin
Kevin's Avatar
i still don't understand why gm made it so damned hard.
Old 08-15-2012   #10
scottfab
scottfab's Avatar
Just Funnin'
Just curious. which MY were you driving and how could we tell?
Scott
