Old 08-14-2012   #1
C4Fanatic
Default The Skunk is in the hospital...
Wish me luck...hope I don't have to sell a kidney to get it out!!!
C4Fanatic is offline   Reply With Quote
Old 08-14-2012   #2
Default Re: The Skunk is in the hospital...
whats the diagnosis?
Old 08-15-2012   #3
C4Fanatic
Don't know yet.
Developed an oil leak up in the front, passenger side, probably one of those many sensors.
And has developed a miss/stumble/stammer, whatever you want to call it. But it doesn't seem to be spark, but more fuel related. Will "hunt" for an idle speed at a stop light sometimes, other times it wants to idle around 1800 rpm, like it has a vacuum leak. And driving down the freeway I could feel it surging at speed, which really bothered me.
Totally bummed at this point.
Old 08-15-2012   #4
mike100
On my car, those same problems ended up being
1) leaky oil cooler lines
2) popped off purge solenoid vacuum line
3) injectors (but item #2 was more like the your description)
Old 08-15-2012   #5
Blue Flame Restorations
My throttle body does the "hunt for a idle speed" thing until I blip the throttle. Sending it to Marc tomorrow for a rebuild.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 08-15-2012   #6
A1990
A1990's Avatar
Sent mine to Marc two years ago for the same problem. Works perfectly since.
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Chairman of the Board
ZR-1 Net Registry Treasurer
A1990 is offline   Reply With Quote
Old 08-15-2012   #7
Which "hospital" did you send it to??
Sounds like some smallish stuff being bigger than the sum of it's parts. The leak - wouldn't be surprised if it was the low pressure (idiot light) switch.
Throttle body prolly needs to be re-bushed or something like that.
No worries. You be fine. Da "skunk" will terrorize again!
P.
Old 08-15-2012   #8
Very likely stickin throttle like mine earlier this year. Marc repositioned the throttle plates and installed helper spring to make sure it closes.
Old 08-15-2012   #9
I've done the grease on the plates trick, spray grease on the shaft ends and blipping the throttle all to make it better. The grease only lasts about a week. Runs great right after lubrication though.
Taking it off and boxing it up in a few minutes. Shipping to Marc tomorrow morning.
Old 08-15-2012   #10
C4Fanatic
Tried the "blip" fix, no help. If it was just the high idle it would have me headed toward the throttle body. But the surge/stumble on acceleration and then surging at cruise speed on the freeway has me leaning a different direction.
Injectors have approximately 27,000miles on them as do the coil packs and wires. Mike had just changed all that right before he sold it to me. So, I hope it's none of that stuff.
Figure the oil leak is the Low Oil sensor, becuase I keep getting that message intermittently.
Don't think she's real crazy about being a daily driver in this Vegas heat, but ya gotta do what ya gotta do sometimes.
