Old 08-12-2012   #1
Default Whats you winter project going to be?
Lets get past some of the negativity, whats the plan for winter; car projects...upgrades, purchases.....
For Me:
1)finish the Callaway TT; new turbos ported heads, bigger valves....if I have time also build the 100+ intake
2)Rebuild the LT-5 for #966
-port heads
-cams
-unsure on 368.......
Old 08-12-2012   #2
Hammer
Hammer's Avatar
Talking Re: Whats you winter project going to be?
72 Nova
Replace the axles - studs are welded in the present ones
Replace the radiator with a 3 core aluminum one
Old 08-12-2012   #3
Blue Flame Restorations
Default Re: Whats you winter project going to be?
Finish EX5023 by Xmas.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 08-12-2012   #4
I will leave spot for that under my tree, feel free to drop it off!
Old 08-12-2012   #5
Kevin
Kevin's Avatar
save up for the tires, ac compressor and whatever else is going to go wrong on this thing
Old 08-12-2012   #6
jimmy b.
jimmy b.'s Avatar
Front shocks, trans and rear axle oil change, also hope to change brake and clutch fluid. Has anybody done this and what brake bleeding tool is best to use?
This year I didn't have the extra cash to buy the tires but should be able to get them next year too.
jimmy b. is offline   Reply With Quote
Old 08-12-2012   #7
vilant
1- have to change the passenger side front shock, so I might as well do them both.
2-still have the original fuel injectors, will have to change them sooner or later
3- definitly have some electrical issues I'll have to pin down.
Old 08-12-2012   #8
Hammer
Hammer's Avatar
  • You can have your front shocks rebuilt by Bilstien $55 ea I think
  • Trans - Castrol 10W60 -You can only get it from BMW dealer, change at 10k to 12k intervals. Make sure to take the fill plug out first. ZFDoc has the best prices on the fill and drain plugs. Doesn't hurt to have a couple laying around just in case. www.zfdoc.com
  • Rear axle - I used Mobil 1 synthetic with a bottle (4 oz) of posi lube
  • Phoenix without question for the clutch and brakes, one man job.
http://www.discounttiredirect.com Nitto NT555 $744 delivered to Idaho
Old 08-12-2012   #9
Hammer
Hammer's Avatar
If you have the time, send them to Bilstein, $55, Lifetime warranty I think
Call Jon at Fuel Injector Connection, I've had his rebuilt injectors in over three years now, no problems at all.
Old 08-12-2012   #10
C6Z or GS brakes in front. That means Brembos would be available.
