Old 08-10-2012   #1
MrsMcNastys
Default Secondary vacuum question
When checking the secondary vacuum pump and line going under the plenum for a vacuum leak, does that same line going to the plenum pull vacuum at idle ?...
i.e. at idle if disconnected the line has engine manifold vacuum, wondering if this indicates a bad reservoir or check valve? Or is that normal?
Ed
MrsMcNastys is offline   Reply With Quote
Old 08-10-2012   #2
MrsMcNastys
Default Re: Secondary vacuum question
Sorry, line fitting disconnected near the oil cooler where you check pump vacuum and plenum line for leak-down.
I am guessing that the pump and vacuum reservoir is for the secondaries at WOT when manifold vacuum drops as just a reservoir by itself would be quickly depleted during a WOT run to top speed, I was just surprised that the manifold vacuum is not isolated from the pump ...
Ed
Old 08-10-2012   #3
Daniel_Mc
Daniel_Mc's Avatar
Dynomite,
Thanks for posting that pic I am having an issue with the secondary system and was looking fro just that pic to make sure it was run correctly.
Daniel
Daniel_Mc is offline   Reply With Quote
Old 08-11-2012   #4
scottfab
scottfab's Avatar
Here is the manual schematic diagram of the vacuum system.
It clearly shows that you would feel vacuum at that point (when disconnected from the pump.
http://zr1.net/forum/album.php?album...pictureid=1351
When the engine is running this vacuum will shut off the air pump if everything is running properly.
Scott
Old 08-11-2012   #5
Ed
Mine does pull a small amount of vacuum when disconnected from the pump,hope its normal.
