Old 07-15-2012   #1
cvette98pacecar
Default Half Shaft
Does anyone sell a heavy duty half shaft?
Old 07-15-2012   #2
Scrrem
Scrrem's Avatar
Default Re: Half Shaft
Don't know how strong your looking for, but had this site bookmarked.
http://www.dennysdriveshaft.com/p127...ous_ready.html
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 07-15-2012   #3
Al snapped the splined shaft on the half shaft. They have anything for that?
Old 07-15-2012   #4
WVZR-1
Spindle at the wheel or the "short-axle" at the differential?
Old 07-15-2012   #5
scottfab
scottfab's Avatar
I have to think Wheel... just guessing based on past readings over the years. And the answer is ??????
Scott
Old 07-15-2012   #6
Blue Flame Restorations
Robert, are you contemplating more cubes?????
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 07-15-2012   #7
Comon problem with the big incher's when they find traction....traction compound. Summer's Brothers axles has a great upgrade. Send them your parts they install a larger bearing that houses they're custom made larger splined shaft. They offer it as a custom service.
Or by putting a automatic in it may help ..?
Old 07-15-2012   #8
WVZR-1
The Summers Bros package if you supplied the spindles and the hub/bearings in '08 - '09 I believe was something near $1000. It was several hundred more with them suppling the parts BUT since the spindles aren't available off the shelf any longer you would I expect only need to supply used spindles. If you had a broken spindle outboard of the u-joint flange I believe they could maybe do their modification using only the u-joint flange. Don't know?
Old 07-15-2012   #9
Broke splined shaft at the wheel hub.
Old 07-15-2012   #10
scottfab
scottfab's Avatar
I am curious. What HP is on the car?
Scott
