Here it is
![]() Join Date: Dec 2004
Nice!
![]() ![]() Okay now for the apprentice's dumb out of left field Q's: That car has a coil over suspension conversion, right? If you do that conversion you still get to keep the FX3 system? If you convert to coil-over is the rear leaf spring also converted to a coil over system or is it just the front? Sorry for the Q's from the peanut gallery ![]() ![]() Tom
#3 | ||
![]() ![]() Join Date: Aug 2005
Wow, those look awesome, Jeff!
Lots 'o questions: Tell us about the conversion- does this use a caliper adaptor plate or did you change everything over to C6? Think there will be any wheel clearance issues? How do you think they compare performance wise with the other aftermarket systems? Last edited by tf95ZR1; 05-17-2006 at 07:58 PM. |
#5 | ||
I'll be test fitting the setup against a Fikse FM5 hopefully this weekend as well as bolting them on for the test drives. Will be burn them in and do some G-tech stops. Performance will be vastly superior to the J55, C5, and the lower end Baer claw systems. Will be on the level with Alcon/Brembo/Wilwood, at a very reduced price. Think around half of what those cost. |
![]() Join Date: Dec 2003
Looking good Jeff, I had faith you would overcome your earlier issues and make this available.
![]() Join Date: Jul 2005
This is a great offering; wish I had the 18 inch wheels to make it work!
How's the ZO6 brakes coming along? They looked killer with an upgrade in performance you can't go wrong. I'm in for a set if it all works out. I have 18" Kinesis wheels to go with them. Thanks for your time and effort.
#9 |
Ricky, The kit is going on a car this week for testing. After that I should have the fronts out the door for those who are interested in two weeks.
#10 |
WILL U BE ABLE TO GIVE US B4 AND AFTER PEFORM. #'S after your testing Jeff? they look sweet!
