![]() Join Date: Jul 2009
I am changing my gas tank on my ZR1.
Do i need a ZR1 specific Gas tank or will any of the c4 tanks do. |
![]() Join Date: Dec 2004
GM P/N 14048936 is the number I get from our parts CD. I think they are all the same.
![]() Tom just did a parts search at GM and it's NLA.
1990 ZR-1, Black/grey, #2233, stock. ZR-1 Net Reg Founding Member #316 & NCM member Last edited by tomtom72; 07-05-2012 at 08:03 AM. |
#4 | |
Tom is right they are C4 specific not ZR-1 specific. GC
What about the bucket/baffle in the bottom of the tank? Is that found in all C4s?
![]() Join Date: Jan 2009
The tank you get should have a rubberized lining. There were some floating around in the 90s with no lining.
Also some made where the rubber lining separates easily.
Are those the tanks that limit the capacity due to an emissions thing or something to that effect?
#9 |
I thought the capacity-limited tanks were those that had a fuel filler neck that extended too low into the tank, causing premature dispenser shutoff. ??
#10 |
Now that you say that I believe you are right.
