Old 04-02-2004   #1
ROGER E
Default #4 NOT FIREING WELL
My lt5's #4 cilynder is missing a lot but not all the time. I replaced plugs, wires and had all injectors cleaned and tested but no change. If i allow #4 spark plug wire to arc to ground the engine will die. Any suggestions???
ROGER E is offline   Reply With Quote
Old 04-02-2004   #2
ZR-1Mom
Default
It might be a bad coil. There is one coil for every 2 plugs. The coils are under the plenum.
ZR-1Mom is offline   Reply With Quote
