![]() Join Date: Jan 2012
You can check out my concerns about doing this myself, along with a number of great suggestions, here: http://www.zr1.net/forum/showthread.php?t=17551
Last Monday, Pete changed the clutch and let me watch :-) Having done this so many times before and having the right tools meant it was a <5 hour job as opposed to the two weeks it would have taken me to fumble around. Here’s Pete working his magic. ![]() I’ll post more pics and some more details later. I’m very late giving this ‘shout out’ to Pete so I want to get this posted at least. The clutch was slipping so bad before that when I pulled off I-294 into Des Plains, the Z took forever to get up to speed from a light. Afterwards, I needed to learn how to drive a clutch again! |
![]() ![]() Join Date: Feb 2010
Pete's DaMan!
![]() Join Date: Aug 2008
Well you know Jeff Flint says it should only take 3 hours from start to finish.
![]() God that looks so much easier with a lift. Doing it with jack stands blows. |
#4 | |
![]() Join Date: Nov 2007
![]() Last time I spoke to Bill Beudreau (ZFdoc.com), he told me he does it on jack stands as well. (That was over 5 years ago, that is). He described how he uses a floor jack and hooks his ankle over the jack handle and prefers to balance the trans on the standard "cup" on the floor jack. Dang if he wasn't right! But! Gimme a lift every time, thank you! ![]() P. |
![]() Join Date: May 2010
There are a bunch of us that have to do this on lying on their back with jack stands. It reminds me of the days when it was so easy to bench press the M21 or M22 Muncies into place. Not the ZF6, that sucker would cave my chest in.........that is one heavy SOB.
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
Couldn't agree more!
Pete is so knowledgable and helpful to all ![]() David |
#7 | |
![]() Join Date: Jul 2005
![]() Join Date: Feb 2011
Last year when Bill B. rebuilt mine, he said that a lift might actually slow him down since they had the trans r&r down to an exact science with the tools he has. Just takes a couple of extra minutes to get the car on stands.
#9 | |
#10 |
![]() Join Date: Mar 2007
PITA part:
1)The U joint strap bolts 2)Getting the shifter to clear 3)Upper bolts on the Bell housing I always have a hard time with the u joint bolts...no dmn room for a wrench
