Old 06-14-2012   #1
Default A question about NOS coolent hose clamps.
Are these the correct clamps that come in an OEM coolant hose set?Ive compared the part numbers with these against a used set of clamps I had and the part numbers arent the same.There is one worm type clamp in the set,no clamp like this is the used set I had but G.M. is always throwing a different part out there that will work in place of an original one.Thanks.[IMG][/IMG]
Old 06-14-2012   #2
vettn71
Default Re: A question about NOS coolent hose clamps.
Those look right. Not sure about the worm-gear clamp. Mine are all the pressure type. There's date codes on them, also.
vettn71 is offline   Reply With Quote
