Old 06-03-2012   #1
Dmod81
Default Coolant air bleed hose leak
My '92 has developed a leak from the driver side plenum coolant air bleed hose at the 90 degree elbow fitting. It seems that the hose has failed as I can see coolant seeping from inside the hose where the threads are. Also, I am getting a small puddle of coolant on the coolant pipe block.
Does anyone know of a source for the hose In question?
Dmod81 is offline   Reply With Quote
Old 06-03-2012   #2
scottfab
scottfab's Avatar
Default Re: Coolant air bleed hose leak
It's common for the 90 deg metal elbow to develop a leak and look like the hose is leaking. This because it is stressed each time the plenum is pulled.
Scott
Old 06-03-2012   #3
Dmod81
Thanks, I thought it might be that, so I checked. It's actually the hose. I can see it leaking out.
Old 06-03-2012   #4
sammy
you can buy 5/16 hose at the auto store and trim to fit , alot cheaper than buying the nos stuff
