Old 05-31-2012   #1
SDZR-1
Default Digital readout says, "sys"
The digital part of the gauges, more particularily where the avg economy is displayed, says, "sys." it will flash this a few times a minute then go back to fuel economy display. Did a search but found nothing. Any ideas?
SDZR-1 is offline   Reply With Quote
Old 05-31-2012   #2
VetteMed
Default Re: Digital readout says, "sys"
I think that's indicative of a trouble code stored in the CCM. Could be a sign of a bad or failing battery, or something as silly as an indicator lamp that is burned out.
Old 05-31-2012   #3
Bad battery
Old 06-01-2012   #4
SDZR-1
Thank you!
Old 06-01-2012   #5
scottfab
scottfab's Avatar
Check the connections at the battery first.
Loose?
Clean, tighten and hit the battery with a charger
then see if it comes back.
Scott
Old 06-01-2012   #6
Kb7tif
Are the digital readings on temp ect, correct?
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 06-02-2012   #7
gunman0
gunman0's Avatar
Have you installed an aftermarket head-unit recently?
91 Black ZR1
DRM Chip
Corsa cat-back
gunman0 is offline   Reply With Quote
