Old 05-30-2012   #1
PhillipsLT5
PhillipsLT5's Avatar
Default Mojave 1.5 Magnum Mile
I am going to run this, this weekend
Any tips?
I have run several 1 mile shootouts before but now I will need to shift into 6the for 1.5 miles, I think it may slow down in 6th?
My car has 422 RWHP, 4.10 gears, elevation is aprox 2700, high temp will be 90, wind 15 to 20(hopefully tail wind)
My car ran the mile at 169.7, close to 7K in 5th
My car ran the 1/4 mile at 118, close to 7K in 4th
Dyno shows no more power gain after 7K
So I am pulling 5th from 1/4 mile all the way to 1 mile, fun ride
My car is tuned for 91 octane as that is all we can get out west, but race fuel will be available
Old 05-31-2012   #2
mike100
Default Re: Mojave 1.5 Magnum Mile
I would try to find a 3.42 center section/batwing to swap in there
Old 05-31-2012   #3
Blue Flame Restorations
Sounds exciting. I'll admit that I juust don't have the guts to do it.
When Rick Mueller had my 91, he did the Texas Mile with a speed of 170.281. He gave me the certificate with the car. Kinda neat.
Good luck and be safe!!!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 05-31-2012   #4
tf95ZR1
tf95ZR1's Avatar
Hi Phillip!
You'll have enough runs, run it both ways and see.
Topped out in 5th, and shifting into 6th. Let us know.
I'm jealous, mine is still up on jack stands, and not smogged
yet. I'll miss this MM. Be safe and good luck to you and Jr!
Old 05-31-2012   #5
PhillipsLT5
no time for rear end swap, 170 is real strong for a mile
new ZO6's doing 172/173, new ZR1's doing 175/176
Old 05-31-2012   #6
hiperf406
hiperf406's Avatar
Good luck - be safe buddy. lorne
lorne # 1748
Stock except for a modified Corsa exhaust.
When the flag drops the bull sh1t stops!
hiperf406 is offline   Reply With Quote
Old 05-31-2012   #7
PhillipsLT5
I can not stay too long, maybe 10 sec at 6K or more due to water pump cavitation
Old 05-31-2012   #8
Tyler Townsley
You need to do a search on my name and read the information on the water flow and thermostat. If you run the car over 5200 rpm your system starts routing the water around the radiator straight to the motor, the heat skyrockets because of this not water pump cavation. If you want to run these events I recommend an aftermarket high flow radiator and cut the thermostat main spring.
Tyler
Old 06-01-2012   #9
PhillipsLT5
I have a stock thermostat, fluidyne radiator, will not get to 5200 in 6th, but I am there for sure climbing in 5th, wiil the temp guage rise or oil temp rise or both rise?
Old 06-01-2012   #10
tf95ZR1
tf95ZR1's Avatar
Hey Phillip
I say no overheating: You will only be at the higher
RPM's for a relatively short period of time compared to
sustained high RPM's when going around a track.
I would be more concerned with ballooning (is that a word?) the
radiator at high pressures/RPM's but I think your/our
systems can handle it.
And remember, its only $$$$!
