Old 05-28-2012   #1
Default Hillbilly Trans Jack
The Ceiling height of my garage does not allow my trans jack to clear the lift ramps......PITA.....
Vid below for a few laughs....
Old 05-28-2012   #2
VetteMed
Default Re: Hillbilly Trans Jack
Youze a strong mofo. I know I couldn't lift my ZF like that.
Old 05-28-2012   #3
If I tried that my left nut would have hit the floor lol
Old 05-28-2012   #4
VetteMed
One of the discs in my back would have shot across the garage if I tried that!
Old 05-28-2012   #5
Lol that was senario number two after the Hernia
Old 05-28-2012   #6
Scrrem
Scrrem's Avatar
Lee,
I have that same issue and I do that same dance myself with one suttle difference. I put the transmission on my motorcycle lift, roll it under the lift then transfer .
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 05-28-2012   #7
Toyvet1
Show Off !!!!
Toyvet1 is offline   Reply With Quote
Old 05-28-2012   #8
USAFPILOT
USAFPILOT's Avatar
well that's the easy way
Old 05-29-2012   #9
scottfab
scottfab's Avatar
The first time I man handled the ZF6 like that I was recovering from back surgery and I used lifting and rebuilding the internals of the thing (3rd syncro and input shaft) as physical therapy. Just a few minutes on the first day then built up the time so I could work on it for a few hours.
The video brings back those memories from 99.
Did you put it on bolt sliders or just hang it by the input shaft?
Scott
Old 05-29-2012   #10
I used bolt sliders...
