05-05-2006 | #1 |
1990 GM Service Bulletins
Anyone know of a source for these? Looking for a copy of Bulletin 90-436-9J.
Thanks, John |
05-05-2006 | #2 |
Re: 1990 GM Service Bulletins
If you are a registry member, they have them on the members site.
05-06-2006 | #3 | |
05-08-2006 | #4 |
90-436-9J relates to the fromunda crud on the mounting ear of the air bag sensors. Oh, I forgot, "fromunda" = From under, that's NYeese for under.
I've been told that Grodon Killabrew(Foryourcar.com) said to clean the corosion at the mounting bolt & brkt & spot on the frame for the bolt boss. Use di-electric grease and add a star washer and re-mount the sensor. I think water has a way of laying there sometimes and causes a bad ground condition. I don't /didn't get any codes on my car but as I had the battery out I went ahead & did the driver's side sensor. The passenger side I have yet to do so I can offer no "insight" to the method of getting to that sensor. Driver's side is easy: Discon battery, remove left rocker panel, remove gill panel & note position of upper shim, remove battery & tray, and air bag sensor is in view on the frame. Yellow wire, large & labeled is the tell tail to the sensor(black box about 2" sq). I would discon batt first before doing anything on the body panels as the warnings about dis-charge of air bad say to wait at least 15 min. before working on SIR wiring & components. Helm manual says that in the "cautions". I followed the "caution". You need torx bits and 13 & 10mm sockets & 1/4" rachet set works fine or 3/8" rachet set. I find the 1/4" set easier to use on stuff like this. Tom
05-08-2006 | #5 |
I have had my air bag light on for over two years now. I have taken both sensors out twice and cleaned them. Tried to clear the code to no avail so I purchase the code clearing gizmo from Corvette Central and still no luck. I just live with the light. Would like to clear but nothing seems to work for me. Would welcome any suggestions!!!!!
05-08-2006 | #6 | |
Just took Gordon's class last week. Both he and Chris are great people. I was looking for the bulletin just to double check myself as I go thru the process. Gordon said to be careful with the di-electric grease, it does not conduct electricity. BTW, I'm from upstate, haven't heard "fromunda" before. Must be a downstate phrase. Thanks again, Regards, John |
05-09-2006 | #7 |
Hi John Man I'm envious of you taking class with Gordon....that's my dream to scrape together enough $ to go the whole route so I can understand this car! It's alot different than my last vette, a 72....and I thought that car was hard to work on!
I haven't done the passenger side yet but if I do I'll report back to this thread on what I find out about how to do it...I know I eye balled it some time ago...I think Aurora40 did his and has some insight into the procedure?? Oh almost forgot, this may be of help. I was over in the C4 section at Corvette Forum and saw an interesting thread about the infl rest light. One member over there had a way to test the sensors and the steering wheel separately. If I can find the thread I'll try to do a link to it. I just have to do a search as it was all new to me & very interesting. Good luck Tom
05-09-2006 | #8 |
Okay now everyone will know the depth of my P/C skills.....
Over at CF in the C4 Tech/performance section on page 2 there is a thread titled "What does "INFL REST" mean?", see reply #5 for the diagnostic procedure I was referring to in my previous post. Sorry about the road map....some day I just may get the hang of this P/C stuff! Tom
05-11-2006 | #9 | |
Gordon's class is a MUST!!! There is nothing he doesn't know. He and Chris are great. Wish I had planned ahead to stay in town for the gathering last weekend. Maybe next year. Diagonosed my car, got a code 16 & 26. Looks like I am going to have to clean up the sensors. If you are going to be up in the Albany area, drop me an e-mail. John |
05-12-2006 | #10 |
John! When I get squared away with my Z for the season I'll for sure drop a line...any excuse to drive mine more than 50 miles, no need to twist my arm!
