Old 05-12-2012   #1
Default Anyone have experience with a Direct Lift Pro Park lift?
I am still researching lifts and have had lots of good feedback on BendPak and some others. I also saw a less expensive one called the Direct Lift (Division of Rotary) Pro Park 8S that is ALI/ETL Certified and also has slightly better dimensions for my garage. I wondered if anyone has experience with this lift. And if there is anyone in the Chicago area with one I would like to see one if possible. Maybe there will be one at Bloomington (which I can only get to on Sunday). Thanks in advance.-Bob
Old 05-12-2012   #2
cvette98pacecar
Default Re: Anyone have experience with a Direct Lift Pro Park lift?
If you are going to BG, Greg smith lifts is located in Indianapolis.
Old 05-12-2012   #3
Good idea but unfortunately I am not going to BG. I will try to make Bloomington Gold at Pheasant Run on its last day and usually they have several lift displays. --Bob
Old 05-12-2012   #4
I have one, its awesome....built it by myself
