Old 05-01-2006   #1
TMORROW
Default water pump
do you have to remove the plenum to remove the water pump? I got all bolts out except for the small (maybe 6mm) that goes down vertical from the a/c unit. My friend has the book, can't get a hold of him.
TMORROW is offline   Reply With Quote
Old 05-01-2006   #2
Jeffvette
Default Re: water pump
You have to remove the air horn at minimum. There is a bolt that goes straight down from the top into the WP.
Old 05-01-2006   #3
TMORROW
Ok, it feels like it going to back up into the alternator very tight. Thanks
