![]() ![]() Join Date: Feb 2010
Learned something this weekend about the TPS (throttle positin sensor).
My car had one with a broken snap tab for holding the connector to the TPS. Evidently, the voltage would not stay consistent due to the broken snap tab. The car ran "ok" but had developed a small "burbble", I call it. You could feel it and hear it in the exhaust. It started last Friday. It had ran 100% after the engine work and it really dis-appointed me to have what felt like a "miss". After discussing it with Pete, we determined that the connector with the missing snap tab may be the issue. I ordered a new pigtail from O'Reiley's and spliced it into the harness today. Walah! Runs like a champ. The cams sound amazing and the exhaust tone is smooth, although pretty loud. I have pretty good neighbors and hope to keep it that way. The B&B with X pipe eliminates me from sneaking into or out of anywhere. LOL With the age of our cars, and plenum pulls, disconnecting and re-connecting, it's really no surprise that this happened on my car. Plastic gets brittle, sepecially in a heated environment.
Great information, I need to replace mine as well.
![]() Join Date: Jan 2009
Do you recall the O'Riley part # ?
Better option than cut and splice, is to get a pin release tool, to allow you to reuse the stock wires and pins in a new connector housing. These tools are sold as a 3-pack, I think I paid about 9 or 10 bucks from jeg's a while back.
Tool and bare wire with pin: ![]() pin inserted into tool, almost to the point where locking tabs are depressed. ![]() Obviously you can't see this when the connector is assembled -- but the process is the same. Last edited by VetteMed; 05-07-2012 at 10:21 AM. |
YEP me too..!
BWD
PT300 If I had known about the tool, I would have refrained from splicing the wires and heat shrinkng them.
#9 |
![]() Join Date: Dec 2003
The OE pins go weak/break.
The 2 i had were broken/weak pins. It's not the plastic plug that makes contact it's the pins and if they're weak or broken you can change the plug and still have the issue. Pete
#10 |
Good point. I had many connectors with brittle, cracked plastic, but no problems with any broken pins.
