Im in the process of building a rear light harness for my Euro taillight conversion and would like to run a duel element bulb for the taillight-brake light function.My question is would a duel filament bulb draw too much current and cause a fuse issue?The second filament would only function in addition with the brake light.
#2 | |
![]() Join Date: Nov 2007
P. |
Ever consider just a hyper bright LEDs? Just a thought
#6 | |
Without over thinking this, if you could read the current with a VOM across the fuse connections (fuse removed for the test) with the lights on, it would go a long way toward developing a basis for a solid analysis and corrosponding answer/recommendation. Can you do that? |
#7 | |
#8 | |
P. |
