Old 05-05-2012   #1
Default LGAFF master fabricator...ok thats a stretch
The Siamese plenum I did I picked up from the Phrog man for a good price.....but the MAP senor brackets were hacked off...
So I figured I would fix it....
Drilled a 6mm hole for stud
Tapped a aluminum spacer from ACE
and alittle JB....
Alittle sanding and it will look stock
Old 05-05-2012   #2
Default Re: LGAFF master fabricator...ok thats a stretch
BRILLIANT!
Old 05-05-2012   #3
Blue Flame Restorations
It's nice being able to do your own work. Feels good, too.
Good job.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 05-05-2012   #4
Good enough
Old 05-05-2012   #5
VetteMed
Looks like it'll do the job.
Old 05-05-2012   #6
QB93Z
QB93Z's Avatar
Nice job Lee.
Old 05-06-2012   #7
Now that's what I'm talkin' about! Lee!
Yea, it does make you feel good when you can get stuff like that dunn!
Old 05-06-2012   #8
Not half bad, Lee! Course powder coating is out of the question, I suppose. I have some "Alumaweld" and a video that shows just such type of reconstruction of aluminum castings. I've played around with the stuff some, and I'm intrigued by how well it might work in just that kind of application. If that epoxy doesn't work out, give me a call, and lets see if this Alumaweld stuff is all its cracked up to be!
P.
Old 05-06-2012   #9
Paul this stuff is good to 600 degrees.....so I am not sure that you could not PC....I used Alumiweld to fill my siamese intake......the issue is getting the parent metal hot enough..I waqs successful once.
I was using MAP...I think with an Oxy torch it would work. Also check out muggyweld.com
Old 05-06-2012   #10
This is the metal putty not the 2 part epoxy....
