Old 04-28-2012   #1
limey
Default Code 41
Briefly, Accessing the Cluster information 4.0 I get a code 41, Car runs awful.
Aftermarket PROM in the car, ported top end, new injectors, just replaced the ECM with known good unit.
Any ideas?
limey is offline   Reply With Quote
Old 04-28-2012   #2
ALZR1
Default Re: Code 41
Any ideas?
Check to see if your prom is inserted correctly.
AL.
ALZR1 is offline   Reply With Quote
Old 04-28-2012   #3
ALZR1
Default Re: Code 41
AL.
here is the chart.
Old 04-28-2012   #4
Default Re: Code 41
Limey,
Is the notch on the prom pointed towards the outside shell of ECM? Just turn ignition key to ON. SES should flash once then stay on. If it flickers, something wrong w prom. Also, aftermarket prom, is it using correct MY Mask ID, ie $8EA(90), AFA(91), D0A(92), F0A(93-95)?
