![]() Join Date: Jan 2007
I had my '92 modded a couple of years ago by a known tuner but I wasn't real happy with some of the results, (rough idle and backfire) so I had Haibeck retune an extra e-prom I had for me to see if I got different results. The mods were;
Ported heads, injector housings and plenum SW headers no cats Corsa exaust 3:92 gears Reset cams and I added K& N filter Relocated temp sensor The Idle is smooth and the backfire is gone but with a hard shift above 6k I get a momentary SES light. Using Gordan's kit I could not find any stored codes, Marc set fuel scheduling for 410/420hp. Any ideas? |
vac leak
![]() Join Date: Dec 2004
It could be you are running out of vacuum and it's setting a DTC 61 intermittently ?? You said hard run to 6+k rpms, and that would be where the manifold vac drops almost to zero and in theory our vacuum pump is supposed to pick up any shortage of vacuum in the system to keep the 2* actuators pulling on the 2* linkage.
Not to be a wise guy, did you use the Gordon jumper for the CCM? I think that's where the history codes and intermittent codes are stored....I think! ![]() ![]() Tom
I tried them all, ECM, CCM etc; nothing. If it is a vacuum leak I wonder why it didn't show up with the other e-prom? But, I'll check all the vacuum lines.
My guess would be a lazy secondary vaccumm actuator under the plenum. One of the pair
Could be running a bit lean at top end depending on what Marc did with fuel. See if you can datalog while you do a run.
#7 | |
![]() Join Date: Nov 2007
Dom, we're starting to think alike...AND DON'T THINK I'M NOT WORRIED!! ![]() p. Last edited by Paul Workman; 04-24-2012 at 03:07 PM. |
#8 | |
