Old 04-19-2012   #1
janozr1
Default high coolant temperature
Hi , need some help.....
after few moments the car is stopped cooling fans go off but cooling temperature still going up . Go back on the road , and temperature dropped to the normal ........... Stickly thermostat ? or what else can be
wrong ? It was first ride today ater long winter slipping .
thanks for any tipps.
Jano
janozr1 is offline   Reply With Quote
Old 04-19-2012   #2
Default Re: high coolant temperature
Jano
Exactly how high did the temperature go up to ?
Old 04-19-2012   #3
janozr1
while Im driving is temperature arround 90 - 92 celsius , when i stopped car temperature start growing and both fans go on at 96 degrees and temperature claimb to 98 and stay there regardless both fans running.
Before today usually fans were put down temperature in cca 10 -15 sec and they turn off at 90 degrees.
Also check cooling level and it is normal
Old 04-19-2012   #4
janozr1
Allready see that i replaced on and off in my first post... sorry for my bad english.
Old 04-19-2012   #5
Thats 208F so no problem.
Old 04-19-2012   #6
janozr1
ok , but still dont understand why temp stay there and doesnt dropp if both fans are running , usually were fans put temperature down and turn off for awhile...
Old 04-19-2012   #7
No problem as stated you are not having a problem those temps are normal.
Old 04-19-2012   #8
janozr1
GOLDSYLON thanks for replys , It is different like before and I will check everything tomorrow when will be coolant cool again ............
best regards , Jano
Old 04-19-2012   #9
ralph92ZR1
ralph92ZR1's Avatar
My 92 has about 22000 miles. 2 years ago, replaced the thermostat and flushed the entire system and filled with GM recommended coolant. With Marc's chip that turns the fans on earlier, even on the hottest days of summer, the temps oscillate from about 197 to 205 deg F. Before this, the hottest was about 230 deg F.
Hope this helps...
[FONT=Franklin Gothic Medium]Ralph E. Weise [/FONT]:)
'92 ZR-1#473
Red/Red
ralph92ZR1 is offline   Reply With Quote
Old 04-19-2012   #10
sammy
have you pulled the radiator cover and see if the fins on your radiator are plugged . our cars are like a hoover vacuum cleaner . they gobble up every thing .plastic bags , leaves and small rodents .jk.i am willing to be that your radiator fins are partially plugged
