I get this flashing at times but not constant.I checked for codes but none at present.Its been awhile since Ive used the A-B terminal trick but checked for codes and got a 12 which If I remember correctly is normal.Any clues?
![]() ![]() Join Date: Aug 2005
Battery or connections.
I'm no expert, but this is what SYS has been for me EVERY TIME. Last edited by tf95ZR1; 04-19-2012 at 12:54 AM. Reason: Wanted 2 |
Battery or alternator. My best guess is battery
![]() Join Date: Jan 2009
Yup, battery. Mine did this both time before replacing it
twice in the last 15yrs.
A-B only displays ECM codes. SYS flashes when the CCM has a code stored.
Jump A to G to display CCM codes.
On a 90 you can get at the ECM codes from the CCM entery.
After in the CCM diag mode press TRIP RESET a few times till you see 4.0. Then Press TRIP ODD a few times till 4.7 is displayed. Press ENG/MET and hold till "---" is displayed. You're there.
Any update Jeff ?
#9 |
Thanks for all the info guys.I put the charger on the battery for awhile,hope its not a loose cable at the starter
#10 |
I got into the CCM and I get the ---,if there are no codes stored is this all I will see or is there another step I need to pull the codes?Im still getting the SYS flashing a few times when driving.
