Old 04-14-2012   #1
1990 quasar blue
Default changing antenna mast
Does anyone remember which way the teeth on the ribbon point? I've read conflicting posts. Some say towards the front and some say towards the drivers side.
TIA,
Mike
Old 04-14-2012   #2
secondchance
Default Re: changing antenna mast
I believe to the driverside.
Old 04-14-2012   #3
1990 quasar blue
Thank you sir. I'll give it a shot.
Old 04-14-2012   #4
gbmidyear66
I don't recall from when I did mine - but you will probably find a piece of the broken mast lodged inside the mechanism (as I did) that will tell you.
gbmidyear66 is offline   Reply With Quote
Old 04-14-2012   #5
secondchance
If it's the actual antenna mast that was broken, a replacementmast can be replaced from the top. If the ribbon was broken, the antenna must be removed, drive gear casing opened and broken ribbon retrieved before the new mast can be installed.
Old 04-14-2012   #6
1990 quasar blue
Thanks guys. The ribbon came out complete on the side of route 95 after I used it to kill a bird at 80 mph. The teeth do in fact face the drivers side. Unfortunately I destroyed the 22 year old grommet. It's looking like those are zr1 specific. Does anyone know where to get one?
