Old 04-06-2012   #1
brodykelly
brodykelly's Avatar
Default ZF6 lube
i will be changing the fluid in the 6speed while i have it out and was wondering what you all are using for lube/quantity, any additive? never changed it so tell me what you think or just go with what the manual suggests?? brody p.
brodykelly is offline   Reply With Quote
Old 04-06-2012   #2
Paul in VA
Default Re: ZF6 lube
My trans was rebuilt/improved by Bill B. and he recommended Castrol 10w-60 synthetic available at the BMW dealerships. Naturally this comes in liter bottles. Takes about 2.2 quarts...
Thanks ... Paul
(Paul in VA)
Paul in VA is offline   Reply With Quote
Old 04-06-2012   #3
Scrrem
Scrrem's Avatar
Check this "Solutions" thread...
http://www.zr1.net/forum/showthread.php?p=83045
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 04-06-2012   #4
brodykelly
brodykelly's Avatar
thank you!! i will try to locate the castrol 10w60!!!! brody p.
Old 04-06-2012   #5
VetteMed
BMW dealers will sell it. easiest way to get it.
Old 04-06-2012   #6
mike100
Been very pleased with the shifting using Amsoil Synchromesh, but it does leak a little bit out of the shifter rod seal. Not sure if the other oil would do that or not.
I'm also using this lube in a newer Mustang.
