Old 04-05-2012   #1
Default Rut Roh E-15 soon
E-15 was given a green light. We will see what it does now.
http://www.businessweek.com/news/201...-ethanol-blend
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 04-05-2012   #2
Kevin
Kevin's Avatar
Default Re: Rut Roh E-15 soon
if what I've read is correct...none of my cars can run that without massive fuel system rebuilds
Old 04-05-2012   #3
efnfast
Feds way of getting the old stuff off the road. Just like ultra low sulfer diesel.
Old 04-05-2012   #4
cvette98pacecar
Wont happen. Here is the problem, it absorbs moisture, are you going to replace fuel systems every 5 years? What are they going to do for serious collector cars that are not driven yearly, allow the moisture to corrode the everything metal from the inside out? Some collections out there have to be in the 100's of millions. Do you think those owners are going to let this happen? While E15 will be processed for morons that will use it E5 will always be readily available.
This is just a gimmick as E85 was, cost per gallon was less at the pump. but, fuel consumption went up, grocery went up because the feed corn that would have been used for agricultural means was used to produce **** gas.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
NCM Lifetime Member #2655
Pacecar Registry Member
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 04-05-2012   #5
efnfast
do you think the feds care about car collectors and their precious old cars?
Old 04-05-2012   #6
Kevin
Kevin's Avatar
no, but you don't get a collection worth hundreds of millions without knowing a few numbers to call when things don't go your way
Old 04-05-2012   #7
cvette98pacecar
Yes, who do you think funds their election campaign.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
1998 Pace Car
Old 04-05-2012   #8
USAFPILOT
USAFPILOT's Avatar
It will ruin your fuel system...without a doubt. It will also have a negative impact on your fuel economy. It will make food prices go up. I hate this crap.
Old 04-05-2012   #9
carter200
carter200's Avatar
Grab your ankles! Another reason to thank OBAMA
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 04-06-2012   #10
efnfast
We (as in we Americans) can't do any better than this? Internal combustion engines are over 100 years old. A 1972 Honda Civic got 50 mpg. Have we forgotten how to do that? We can put a man on the moon, or at least we used to be able to, but we can't do any better than 25 or mpg in our cars. I think there might be something wrong. Thank you for listening, I feel a little better now.
